engine momentarily dies, CAT light comes on
vag scan injectors and voltage measuring blocks-run log until it happens
then you may be able to determine wether it is electrical or fuel.
does it only happen at idle or under load?
there is an air control for the injectors valve at address 035 and an idle air control valve that may be faulty[this requires manual check]
If you need doc please email me
Did it go into limp mode? When I put my cone filter in. It was a really hot day and the rubber
hose must have stretched a little to allow the cone filter to slip off, with the MAFS causing CEL, and PRND43 to light up.
jwa9681
Audi A3 / S3 / RS 3
05-18-2007 11:36 AM
