Oxygen Sensor Replacement
Bentley says the exhaust downpipes have to come off to change the fronts (only ones worth changing since the rears do basically nothing...fronts adjust fuel mixture)...BUT this not so, just need a the proper extensions and a O2 sensor socket (cheap). The drivers side should be easy to see, if you know where to look...the passenger side is a little tougher.
Here is a rough description of replacement the easy way on a facelift A8 (similar) >>>
http://forums.quattroworld.com/a8/msgs/49929.phtml
P.S. Bosch universals (for your year car) are cheaper and exactly the same sensor...you just have to splice in your old electrical plug (easy and connection provided with kit).
It is an easy job to do like silverd2 said.
Sorry to say I did not get any better MPG's. Still feel ok that I changed them.
I found the sensors with original plugs for maybe 5 bucks more each. I know, most would say, why spend the 10 dollars? I had visions of getting the job done and one of the wires being loose... Maybe that does not happen??
Good Luck!
Good Luck!
40V Bosch universals can be had for $50 (or less) each, when Bosch OEM plug-n-plays are double (or more) the price at the same seller.
Cheap tools with extensions will do it easily. Alldata, Bentley and Audi dealers are full of crap in this case...all 3 get exactly the same info straight from Audi. NO one changes those sensors by dropping the exhaust down pipes...not even the dealer, but they'll you charge as if they did...that's REALLY the way it works.
Put an Audi tech on a lie-detector and you'd know the truth:
Their records have to show that they went by the book (liability), but they take the shortest route for profit...and because it just makes more sense...minimum disassembly.
Anyway, my car seemed to running perfectly and getting good mileage. I only gained about 1 - 1.5 mpg (which ain't bad), but much more importantly WAY smoother idle and low rpm smooth power...like new again...hadn't noticed the slow decline in running quality till I did the job.
Suit yourself. The job is VERY doable from above. An 02 socket is only about $7 ...available all kinds of places.
