Sponsored by:
Sponsored by:
serp belt
Old 08-22-2005, 04:30 AM
Junior Member
marcodant's Avatar
Default serp belt
anyone ever replace their serp belt? Looks like a PITA. Any help would be great thanks again
Old 08-22-2005, 05:12 AM
PaulW's Avatar
Default It's easy
Take off the belly pan, then put a socket on the tension to relieve tension, then put a torx bit or equivilant to hold the tension off:
<img src="http://www.audipages.com/Tech_Articles/enginemechanical/tbp75.JPG">
Or follow the procedure below, it has everything on it. It only takes a few minutes.<ul><li><a href="http://www.audipages.com/Tech_Articles/enginemechanical/oilcoolerremovalreinstall.html">http://www.audipages.com/Tech_Articles/enginemechanical/oilcoolerremovalreinstall.html</a</li></ul>
Old 08-22-2005, 05:24 AM
Junior Member
marcodant's Avatar
thanks for both answers buddy I am glad I did not have to take the front of the car off
Old 08-22-2005, 05:30 AM
PaulW's Avatar
Why do you need to change it? They essentially never go bad, do it with the TB change out
Old 08-22-2005, 05:44 AM
Junior Member
marcodant's Avatar
Default I still have that squeeling going on only on very hot humid days.. It does not
happen all the time but does happen most of the time on hot humid days. I want to rule out the A/c.. Like I stated before that when I turn the ac off the noise stops. But again the noise is not all the time. and when I rev the eng it goes away after a few revs. then it may or maynot happen when I drive. On hot days but not humid there is no noise. I used belt dressing but seems not to help.. the other option would be to tighten the belt. any other thoughts??
Old 08-22-2005, 05:45 AM
PaulW's Avatar
Belt is tightened automatically by the tensioner, cannot adjust
Old 08-22-2005, 05:49 AM
Junior Member
marcodant's Avatar
Default So what do you think?? belt?? I would think the ac if it was all the time but it is not
I am thinking the belt because of this reason.. get humid; little oil, grim etc...
Gary Knox
06-02-2016 05:09 AM
Vernon
03-12-2009 12:15 PM
KYNZ
13
07-29-2008 12:26 PM
GDawgA4
40
10-27-2006 07:23 PM
Bvarghese
09-21-2005 04:16 AM
Quick Reply: serp belt
