2006 Audi A8L D3 Front Suspension Dropping WEIRD!!!
There is something very weird happening with my car.
I replaced the front suspension last year with re-manufactured and everything was fine until a month ago when I start noticing that front left was dropping all the way down over night.
What's weird about it is that it will not drop at all while sitting at work for 12 hours but it will drop in 6-8 hours in front of my house.
It seems that it started happening when the weather got cold.
Would temperature have something to do with it?
Also, when I try to lift it the yellow and green light start flashing and Lift and Dynamic are shaded gray (not clickable) so I have to restart the car several times to reset the system in order to be able to lift the car.
Any ideas?
If the suspension is leaking shouldn't it leak at the work parking lot?
Is there a one way check valve in the strut so once it's up it will stay up?
Any help or ideas would be greatly appreciated.
Any ideas?
Nothing weird about it
You have the classic symptoms of a failing strut, you may well have replaced that particular unit but from what you have said it's more than likely that that strut has failed and is dropping, cold weather is nearly always mentioned in strut failure threads so it would seem that you need to replace that strut.
But it would pay to do your due dilagence and spray the valve block, strut etc with soapy water to make sure it's not something simple like a connection or airline leaking.
I removed all lines from the block last week and vacuum tested it for leaks but it was fine.
I friend of mine totaled his A8 so I was even thinking to borrow his pump & block to see it will makes any difference.
I'll advise what i find out....
+1 on Strut Leak and Cold Weather
Yes, I was planning on doing that either today or early next week.
I had a bad front right strut and what you described is a lot like my symptoms. Using VCDS, I could see that the height was lower on the corner with the bad strut and usually a little higher on the opposite rear corner. Putting the car on ramps and using the soapy water trick confirmed the leak, with a big bubble blowing up toward the bottom of the strut assembly.
I tried the Jack mode but it still drops.
I will have to put it on Ramps and spray the Soapy water around the shock to confirm that the strut leaking.
AudiWorld Wiseguy
Right, if there is a leak it will still drop. Presuming it's still the front left that's dropping, then that confirms it's that strut/airline where the problem lies.
'06 A8. I'm going through the same crap right now -front passenger side. Cold weather drops over night and is stuck slammed in the am. Takes 15 minutes of driving and starting the car a few times to get it to go up. When I lock the car it auto levels and i can hear the slightest hiss from that wheel well. But is this a sensor telling it to drop? Or a leak. Couldnt find any leaks with soapy water.. Is it the relay or fuse ? The compressor still works and the car rides fine within 20 mins. F. This is very frustrating. Car is at mechanic now... Not sure whats going on yet..
Can't be much easier than that.
