2009/2010 nav road map?
How can I make this disc work with my Nav system in may 2007 S8? (8PO919884AH 2009/2010 Digital Road Map< North America)
many thanks,
many thanks,
Should work simply by inserting it into the drive. Do you have an older version that works? If not you may have an issue with the drive itself.
Navigation unit can't read DVD. It can be poor quality of DVD if it is home burnt one, unit itself, or most likely both. Cleaning laser lens helps a bit, but not for long. New (factory refurbished) units are available for ~$800.
2007 works fine
The 2007 disc works fine. This one which looks exactly the same, only the date(s) is different. I'll try it in a buddy's '08 S8 perhaps.
NewYorkDesigner
20
09-15-2007 06:10 AM
arclinear
A4 (B7 Platform) Discussion
05-05-2005 05:30 AM
