Sponsored by:
Sponsored by:
AAC retrofit and Instrument cluster swap
Old 02-29-2016, 09:02 AM
  #61
mmi.drachten's Avatar
I just swapped my old instrument cluster to be sure this cluster is not responsible for this mess.
But unfortunate I cannot activate ACC in 17 INSTRUMENT Ross-Tech: VCDS Tour 10 adaptation channel 17=1. (0=ACC OFF / 1 = ACC ON).
Old 02-29-2016, 09:12 AM
  #62
#58 Did you also have the gearbox mapped to raise the torque limits?
MMI.Drachten: I am not aware the gearbox is remapped.
Question:
Can this be done by the motor software?
Or by OBD?
Or do you physical have to connect the computer to the gearbox module?
Old 02-29-2016, 02:56 PM
  #63
Club AutoUnion
Mrclopec's Avatar
Originally Posted by mmi.drachten
Hi, yes I did read post #52.
Sorry I didn't respond yet...
I still have a second (spare) radar, type F. The idea is to test this radar previous to the eventually software flash.
As the radar is installed behind the grille and the entire bumper needs to be removed I need to find so time. But I will install the spare (model F) radar as soon as possible.
I will keep you updated.
The 'H' gateway is equally as important. It is the "gateway" that allows various modules to communicate with one another. I would think having the incorrect gateway would be the first step in correcting your DTC issue.
Old 05-26-2016, 01:35 PM
  #64
I installed the gateway 4E0907468H today.
No result......
Next step is to swap the radar 4E0907561E into 4E0907561F
Old 05-30-2016, 03:09 PM
  #65
Club AutoUnion
Mrclopec's Avatar
No result......
Good idea.
Old 05-31-2016, 10:35 AM
  #66
I'm a little stubborn,.............. they say ;-)
Old 06-11-2016, 01:54 PM
  #67
The ACC is working!!
The 4E0 910 561 E radar sensor software version was to old for my 2008 A8 4.2TDI
I swapped this old sensor for version 4E0 910 561 F .
I would like to thank anyone for their contribution!
Case closed!
Old 06-12-2016, 11:29 AM
  #68
Old 08-17-2017, 12:05 AM
  #69
Originally Posted by haggisuk
It's entirely possible, did you also have the gearbox mapped to raise the torque limits?
If you have then I would go back to the tuner and have them reflash the gearbox back to standard to see if the issues you have with ACC and no acceleration in 4th go away.
UPDATE:
Finally I solved this problem by re-flash the original motor software. The cartuner made a WRONG tuning. Probably he modified the Q7 4.2 TDI software and put it into my A8 4.2 TDI. Thank you so much ;-(
Old 08-17-2017, 09:42 AM
  #70
haggisuk's Avatar
A working ACC is a beautiful thing, I'm in Germany at the moment and enjoying the Autobahns shame the ACC only goes to 120 MPH but otherwise its a great option and I wouldn't have another car without it.
Quick Reply: AAC retrofit and Instrument cluster swap
