Air Suspension data needed/Help, please
#21
Ill get you the readings from my car in the next couple days. My suspension seems to be holding air. I left it in lift setting before I put it in jack mode. Should I have put in in comfort or automatic? Does it make a difference?
#22
Things I have noticed when parking / stopping
- When turning off the car, locking it there is a pressure release and the front end lowers some. (After-run mode)
- Starting the car the front end raises back up after it has dropped per above. (Pre-travel mode)
- Compressor turns on at 25 MPH if needed (22 per study guide). Turns off when stopped. So runs a lot to get to 16 BAR when in traffic. Normal operation.
- Pressure builds to 16 BAR then turns off . Car reads between 1.9 and 3 BAR after compressor turns off. (Measuring blocks 3 and 6 if I recall) Is this normal? Appears this is normal and is nothing more than a residual reading.
- Pressure builds when driving approx. 25 Miles in stop and go. Builds to 5-9 PSI. Residual from last checked axle?
- When lowing (auto to dynamic) pressure is bleed off and does not go back into the accumulator. Makes sense as the accumulator may have 16 BAR and the springs less than that.
#23
where did you find the oring for the lines going to the valve block? It seems to be a crazy thing to source. I did some troubleshooting and removed the 2 lines going to the front suspension and the orings look flat.
#24
<!--td {border: 1px solid #ccc;}br {mso-data-placement:same-cell;}-->If you're playing gambling games then you wish to be a lot of careful as a result of you need to follow every step which may assist you to create cash through casino games. I actually have tried to ascertain the gambling games on hoices which supplies the Party Casino options and it can help you to induce the play tricks that is useful for assembling the reward points online easily.
#25
If you're playing gambling games then you wish to be a lot of careful as a result of you need to follow every step which may assist you to create cash through casino games. I actually have tried to ascertain the gambling games on lifestyle sports ireland choices which supplies the Party Casino options and it can help you to induce the play tricks that is useful for assembling the reward points online easily.
Bazzer123
06-20-2018 10:07 PM
Eddyg
01-23-2016 07:54 AM
