Sponsored by:
Sponsored by:
bluetooth Help
Old 07-21-2013, 05:44 PM
viper04's Avatar
Default bluetooth Help
Guys once again I need your help in figuring out how I can get my Bluetooth up and running. I have read as many post as I could find to see if I could get it working but what I am getting in the MMI is "phone is not installed", not sure what it means and where to go from here. Any input would be great. 2006 A8, as the phone cradle. My understanding is that the bluetooth and cradle are independent. Thanks for any input.
Old 07-21-2013, 07:46 PM
mishar's Avatar
You need VCDS scan. Your Bluetooth may be turned off or not set properly.
Take some time and fill your profile. It helps to know where are you and what year is your A8.
Old 07-21-2013, 10:38 PM
viper04's Avatar
Mishar
Thanks for the reply, It's a 2006, Still waiting for my VCDS cable to get here. Any walk though on how to turn Bluetooth back on. Thanks
Old 07-22-2013, 07:21 AM
mishar's Avatar
Once you have it perform a scan and if you do not have Telephone Module (77) go to Gateway Module > Installed List and check Telephone. If it is already on you will have some error codes. Post them here.
Old 07-22-2013, 06:49 PM
nathanwind's Avatar
Is there a phone plugged into your cradle (ie the Audi phone that came with your car, not your phone)? If so just having that phone in the cradle overrides the Bluetooth - simply pop it out if the cradle if it is in there and Bluetooth will work.
If that's not the issue, then do as mishar says .
Old 07-23-2013, 03:37 AM
viper04's Avatar
Mishar
Thanks again for the reply, Will do as you say and post it when I get it.
Old 07-23-2013, 03:40 AM
viper04's Avatar
Nathanwind
No phone in the cradle, but thanks for the input.
Old 07-23-2013, 05:04 AM
PCC
PCC's Avatar
I have the same issue so look forward to any additional input
Old 08-01-2013, 01:40 PM
viper04's Avatar
Here is what I got after doing the scan. Thanks for any help/input.
Thursday,01,August,2013,16:31:13:03502
VCDS Version: Release 11.11.6 (x64)
Data version: 20121223
Chassis Type: 4E0
Scan: 01 02 03 05 06 07 08 09 0E 0F 15 16 17 19 25 28 34 36 37 38
42 46 47 4F 52 53 55 56 61 62 65 67 72 76 77
VIN: WAULL44E06N013650 Mileage: 181180km/112580miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: Malfunction 0010
07-Control Head -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: Sporadic communication error 1000
0F-Digital Radio -- Status: Sporadic communication error 1000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
28-HVAC, Rear -- Status: OK 0000
34-Level Control -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: OK 0000
38-Roof Electronics -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: Sporadic communication error 1000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: Malfunction 0010
56-Radio -- Status: Sporadic communication error 1000
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: Malfunction 0010
65-Tire Pressure -- Status: OK 0000
67-Voice Control -- Status: Sporadic communication error 1000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: Cannot be reached 1100
Address 01: Engine Labels: None
Part No SW: 4E0 910 560 P HW: 4E0 907 560
Component: 4.2L V8/5V G 0010
Revision: --H01--- Serial number: AUX3Z0E9777725
Coding: 0007773
Shop #: WSC 02313 785 00200
VCID: 2E53E724B91AEB68827
3 Faults Found:
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 001 - - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 1
Mileage: 180787 km
Time Indication: 0
Freeze Frame:
RPM: 955 /min
Load: 31.4 %
Speed: 0.0 km/h
Temperature: 47.0°C
Temperature: 31.0°C
Absolute Pres.: 0.0 mbar
Voltage: 12.573 V
16692 - Cylinder 8
P0308 - 001 - Misfire Detected - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 180787 km
Time Indication: 0
Freeze Frame:
RPM: 936 /min
Load: 27.4 %
Speed: 0.0 km/h
Temperature: 48.0°C
Temperature: 31.0°C
Voltage: 12.446 V
16497 - Intake Air Temp. Sensor (G42)
P0113 - 002 - Signal too High - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 1
Mileage: 181023 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 21.0°C
Temperature: -40.0°C
Voltage: 11.303 V
Readiness: 0000 0000
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4E1 910 156 E HW: 09E 927 156 B
Component: AG6 09E 4,2L5V USA 0100
Revision: --H01--- Serial number: 0070274
Coding: 0000002
VCID: 25411808ECECA83073D
No fault code found.
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 B HW: 4E0 614 517 BC
Component: ESP 5.7 allrad H44 0510
Coding: 0008597
Shop #: WSC 08221 000 00000
VCID: 224B0314FDC25F0816F
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 L
Component: FBS AUDID3 H08 0160
Revision: 01604808 Serial number: AUX3Z0E9777725
Coding: 0410624
Shop #: WSC 02311 785 00200
VCID: D8BFE1FC6B1E45D8B8B
Part No: XXXXXXXXXXX
Component: ELV XXXX
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 D HW: 4E0 959 760 B
Component: Sitzmemory BFS H01 0010
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 4071648
Shop #: WSC 00000 785 00200
VCID: 2447050CE7D65138643
1 Fault Found:
02317 - Potentiometer for Lumbar Height / Massage (G423)
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 4
Fault Frequency: 10
Reset counter: 136
Mileage: 180468 km
Time Indication: 0
Date: 2013.07.01
Time: 12:31:36
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 732 S HW: 4E0 035 729
Component: Interfacebox H43 4610
Revision: 00000000 Serial number: 346ET067533258
Coding: 0000103
Shop #: WSC 08221 444 83902
VCID: 326BF354AD22CF88E6F
Part No: 4E0 910 609 C
Component: Bedienteil MMI H42 0100
4 Faults Found:
00003 - Control Module
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 5
Fault Frequency: 1
Reset counter: 104
Mileage: 181185 km
Time Indication: 0
Date: 2110.03.31
Time: 19:51:38
02244 - Button in Control Head is Stuck
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 5
Fault Frequency: 2
Reset counter: 143
Mileage: 181111 km
Time Indication: 0
Date: 2013.07.28
Time: 00:12:02
Freeze Frame:
Bin. Bits: 01000000
Bin. Bits: 0000000
Bin. Bits: 001
01310 - Level Control System Control Module (J197)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 119
Mileage: 180658 km
Time Indication: 0
Date: 2013.07.15
Time: 10:13:24
00384 - Optical Databus
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 5
Reset counter: 39
Mileage: 180787 km
Time Indication: 0
Date: 2013.07.18
Time: 17:55:15
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 B HW: 4E0 820 043 E
Component: KLIMAAUTOMAT 016 0400
Revision: 00000030 Serial number: 00000000078707
Coding: 1118545
VCID: 1C373DECDFA669F8DC3
Part No: 4E0 910 772 A
Component: Sitzluefter FS H02 010
Component: Sitzluefter BFS H02 010
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 L HW: 4E0 907 279 L
Component: ILM Fahrer H13 0210
Coding: 0143123
VCID: 3169FC58A824F4909F5
Subsystem 1 - Part No: 4E1 910 113 B
Component: Wischer WWS D3 H50 0400
Coding: 00000034
Shop #: WSC 02313
Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH10 0050
Coding: 00139548
Shop #: WSC 02313
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 F HW: 4E0 035 111 A
Component: CD-Changer H44 0470
Revision: 00000000 Serial number: AUZ5ZBE7258604
Shop #: WSC 00000 000 00000
Address 0F: Digital Radio Labels: 4E0-910-593-XM.lbl
Part No SW: 4E0 910 593 G HW: 4E0 035 593 C
Component: SDAR XM H04 0670
Revision: 00000000 Serial number: AUZ4Z7E2036341
VCID: 2B55EE308A089E40A59
Address 15: Airbags Labels: 4E0-910-655-94.lbl
Part No SW: 4E0 910 655 C HW: 4E0 959 655 J
Component: Airbag 9.41 H12 4030
Revision: 91H12400 Serial number: 0037Q0002U1Q
Coding: 0532707
Shop #: WSC 08214 444 83879
VCID: 26431F0491EAA3287A7
Part No: 4E0 910 339
Component: BF-Gewichtsens. H01 0030
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 A HW: 4E0 953 549 B
Component: J0527 0310
Revision: 00H01000 Serial number: 90026051970002
Coding: 0012241
Component: E0221 H07 0090
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 950 Q HW: 4E0 920 950 Q
Component: KOMBIINSTR. VDO H71 0400
Revision: D02 Serial number: AUDID3E9001604
Coding: 0048263
Shop #: WSC 40821 444 103281
Address 19: CAN Gateway Labels: 4E0-910-468.lbl
Part No SW: 4E0 910 468 B HW: 4E0 907 468 E
Component: Gateway H11 0090
Revision: 11 Serial number: 2000305A258017
Coding: FCFE7FDD1B7904
VCID: 275D120096E0BA20411
7 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 125
Mileage: 180787 km
Time Indication: 0
Date: 2013.07.18
Time: 18:12:45
01304 - Radio
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 125
Mileage: 180787 km
Time Indication: 0
Date: 2013.07.18
Time: 21:07:18
01301 - Control Module for Voice Recognition (J507)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 125
Mileage: 180787 km
Time Indication: 0
Date: 2013.07.18
Time: 21:09:39
02076 - Media Player Position 1 (R118)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 125
Mileage: 180787 km
Time Indication: 0
Date: 2013.07.18
Time: 21:16:10
02230 - Digital Radio (DAB) (R147)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 125
Mileage: 180787 km
Time Indication: 0
Date: 2013.07.18
Time: 21:21:09
01303 - Telephone Transceiver (R36)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 113
Reset counter: 104
Mileage: 180787 km
Time Indication: 0
Date: 2013.07.18
Time: 21:25:32
00463 - Control Module for Digital Sound Package (J525)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 125
Mileage: 180787 km
Time Indication: 0
Date: 2013.07.18
Time: 23:03:49
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0410624
Component: ELV XXXX
XXXXXXXXXXX ELV XXXX
Address 28: HVAC, Rear Labels: None
Part No SW: 4E0 910 158 HW: 4E0 919 158 A
Component: KLIMA-STG. FOND 015 0220
Revision: 00000018 Serial number: 00000000033570
Coding: 0000000
VCID: E1C9CC1838448410CF5
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 H HW: 4E0 907 553 F
Component: LUFTFDR.-CDC H06 4480
Coding: 0015510
VCID: 285F113C9BFEB55848B
1 Fault Found:
01583 - Leak in System Detected
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 119
Mileage: 180658 km
Time Indication: 0
Date: 2013.07.15
Time: 10:12:11
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H01 0010
Coding: 4071658
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 887 N HW: 4E0 919 887 C
Component: MNS US H45 0740
Revision: 00000000 Serial number: 355JV057556008
VCID: 387FC17C4B5E25D8D8B
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135
Component: Dachknoten D3 H02 0090
Serial number: 00000526600060
Coding: 0003477
VCID: 1D3130E8C4BC60F02BD
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 801 B
Component: Türsteuer.FS BRM003 0100
Coding: 0032364
VCID: 204F091CF3CE4D1800B
1 Fault Found:
02126 - Central Locking Button; Exterior Door Handle
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 3
Fault Frequency: 3
Reset counter: 0
Mileage: 180976 km
Time Indication: 0
Date: 2013.07.23
Time: 12:31:24
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 B HW: 4E0 907 289
Component: Komfortgeraet H05 0010
Revision: 00100005 Serial number: W040510280011
Coding: 0048702
Part No: 4E0 910 853
Component: Heckdeckel P14H06 0070
Part No: 4E0 907 719
Component: Neigungssensor H04 0020
1 Fault Found:
02107 - Trunk or Luggage Compartment Opening Motor (V254)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 114
Mileage: 180623 km
Time Indication: 0
Date: 2013.07.01
Time: 20:50:27
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 P HW: 4E0 035 223 A
Component: DSP-Amp.-High H13 0460
Revision: PROD_01 Serial number: 00000000002965
Coding: 0000016
VCID: 2A5BEB3485F287485EF
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
Component: ILM Beifahrer H11 0070
Revision: Serial number: 00000000073025
Coding: 0010111
VCID: 1E3337E4C9BA7BE8327
Part No: 4E0 910 511 A
Component: UGDO HL US H04 0050
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 802 B
Component: Türsteuer.BF BRM003 0100
Coding: 0032364
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 C HW: 4E0 907 801 A
Component: EPB A32C0220 H02 0220
Revision: A32C0220
Coding: 0000532
Shop #: WSC 08255 444 194608
VCID: 1F4D0AE0CEB072E0391
Address 55: Xenon Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 C HW: 4F0 907 357 C
Component: AFS 1 H01 0030
Revision: 00000001 Serial number:
Coding: 0000018
Part No: 4F0 941 329 B
Component: AFS-Modul links H02 0020
Component: AFS-Modul rechtsH02 0020
1 Fault Found:
02629 - Sensor for Swivel Module Position; Left
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 3
Reset counter: 40
Mileage: 180264 km
Time Indication: 0
Date: 2013.06.30
Time: 14:59:35
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 T HW: 4E0 035 541 E
Component: TUNER EU/US/RDW H42 0630
Revision: 00000000 Serial number: 396JR057530160
Coding: 0000002
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H12 0550
Revision: 00000000 Serial number: 00000000003957
Shop #: WSC 08221 444 54358
Subsystem 1 - Part No: 4E0 915 105 A
Component: von VA0 300610A1KP
Coding: 344530393135313035412056413033303036313041314B50
5 Faults Found:
02272 - Quiescent Current Stage 1
Freeze Frame:
Fault Priority: 7
Fault Frequency: 16
Mileage: 169512 km
Time Indication: 0
Date: 2012.12.23
Time: 20:27:07
02273 - Quiescent Current Stage 2
Freeze Frame:
Fault Priority: 7
Fault Frequency: 11
Mileage: 169512 km
Time Indication: 0
Date: 2012.12.23
Time: 20:33:41
02276 - Quiescent Current Stage 5
Freeze Frame:
Fault Priority: 7
Fault Frequency: 7
Mileage: 169512 km
Time Indication: 0
Date: 2012.12.23
Time: 20:33:52
02274 - Quiescent Current Stage 3
Freeze Frame:
Fault Priority: 7
Fault Frequency: 7
Mileage: 169512 km
Time Indication: 0
Date: 2012.12.23
Time: 20:34:02
02275 - Quiescent Current Stage 4
Freeze Frame:
Fault Priority: 7
Fault Frequency: 4
Mileage: 181185 km
Time Indication: 0
Date: 2013.07.31
Time: 15:00:58
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 801 C
Component: Türsteuer.HL BRM003 0100
Coding: 0032364
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 144
Mileage: 181120 km
Time Indication: 0
Date: 2013.07.28
Time: 13:27:04
Address 65: Tire Pressure Labels: 4E0-910-273.lbl
Part No SW: 4E0 910 273 HW: 4E0 907 273
Component: Reifendruck 2 H01
Revision: 00010028 Serial number: 00000900034395
Coding: 0232125
VCID: DFCDCAE00E30B2E0F91
1 Fault Found:
01521 - Sensor for Tire Pressure
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 128
Mileage: 170388 km
Time Indication: 0
Date: 2013.03.19
Time: 10:06:55
Freeze Frame:
Speed: 17.0 km/h
Temperature: -1.0°C
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 Q HW: 4E0 035 753 A
Component: SDS 3501 US H45 0630
Revision: 00000000 Serial number: 00000510110081
Shop #: WSC 12336 024 394758
VCID: 3467F54C5736C1B8F43
Old 08-01-2013, 02:09 PM
viper04's Avatar
Chassis Type: 4E0
Coding: 0007773
3 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 180787 km
Time Indication: 0
Freeze Frame:
RPM: 955 /min
Load: 31.4 %
Speed: 0.0 km/h
Temperature: 47.0°C
Temperature: 31.0°C
Voltage: 12.573 V
16692 - Cylinder 8
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 180787 km
Time Indication: 0
Freeze Frame:
RPM: 936 /min
Load: 27.4 %
Speed: 0.0 km/h
Temperature: 48.0°C
Temperature: 31.0°C
Voltage: 12.446 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 181023 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 21.0°C
Voltage: 11.303 V
Coding: 0000002
Coding: 0008597
Coding: 0410624
Component: ELV XXXX
Coding: 4071648
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 10
Reset counter: 136
Mileage: 180468 km
Time Indication: 0
Date: 2013.07.01
Time: 12:31:36
Coding: 0000103
4 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 104
Mileage: 181185 km
Time Indication: 0
Date: 2110.03.31
Time: 19:51:38
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 143
Mileage: 181111 km
Time Indication: 0
Date: 2013.07.28
Time: 00:12:02
Freeze Frame:
Bin. Bits: 01000000
Bin. Bits: 0000000
Bin. Bits: 001
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 119
Mileage: 180658 km
Time Indication: 0
Date: 2013.07.15
Time: 10:13:24
Freeze Frame:
Fault Priority: 5
Fault Frequency: 5
Reset counter: 39
Mileage: 180787 km
Time Indication: 0
Date: 2013.07.18
Time: 17:55:15
Coding: 1118545
Coding: 0143123
Coding: 00000034
Shop #: WSC 02313
Coding: 00139548
Shop #: WSC 02313
Coding: 0532707
Coding: 0012241
Coding: 0048263
7 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 125
Mileage: 180787 km
Time Indication: 0
Date: 2013.07.18
Time: 18:12:45
01304 - Radio
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 125
Mileage: 180787 km
Time Indication: 0
Date: 2013.07.18
Time: 21:07:18
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 125
Mileage: 180787 km
Time Indication: 0
Date: 2013.07.18
Time: 21:09:39
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 125
Mileage: 180787 km
Time Indication: 0
Date: 2013.07.18
Time: 21:16:10
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 125
Mileage: 180787 km
Time Indication: 0
Date: 2013.07.18
Time: 21:21:09
Freeze Frame:
Fault Priority: 3
Reset counter: 104
Mileage: 180787 km
Time Indication: 0
Date: 2013.07.18
Time: 21:25:32
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 125
Mileage: 180787 km
Time Indication: 0
Date: 2013.07.18
Time: 23:03:49
Coding: 0410624
Component: ELV XXXX
Coding: 0000000
Coding: 0015510
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 119
Mileage: 180658 km
Time Indication: 0
Date: 2013.07.15
Time: 10:12:11
Coding: 4071658
Coding: 0003477
Coding: 0032364
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 0
Mileage: 180976 km
Time Indication: 0
Date: 2013.07.23
Time: 12:31:24
Coding: 0048702
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 114
Mileage: 180623 km
Time Indication: 0
Date: 2013.07.01
Time: 20:50:27
Coding: 0000016
Coding: 0010111
Coding: 0032364
Revision: A32C0220
Coding: 0000532
Coding: 0000018
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 40
Mileage: 180264 km
Time Indication: 0
Date: 2013.06.30
Time: 14:59:35
Coding: 0000002
5 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 16
Mileage: 169512 km
Time Indication: 0
Date: 2012.12.23
Time: 20:27:07
Freeze Frame:
Fault Priority: 7
Fault Frequency: 11
Mileage: 169512 km
Time Indication: 0
Date: 2012.12.23
Time: 20:33:41
Freeze Frame:
Fault Priority: 7
Fault Frequency: 7
Mileage: 169512 km
Time Indication: 0
Date: 2012.12.23
Time: 20:33:52
Freeze Frame:
Fault Priority: 7
Fault Frequency: 7
Mileage: 169512 km
Time Indication: 0
Date: 2012.12.23
Time: 20:34:02
Freeze Frame:
Fault Priority: 7
Fault Frequency: 4
Mileage: 181185 km
Time Indication: 0
Date: 2013.07.31
Time: 15:00:58
Coding: 0032364
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 144
Mileage: 181120 km
Time Indication: 0
Date: 2013.07.28
Time: 13:27:04
Coding: 0232125
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 128
Mileage: 170388 km
Time Indication: 0
Date: 2013.03.19
Time: 10:06:55
Freeze Frame:
Speed: 17.0 km/h
Temperature: -1.0°C
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Sorry missing some part of the scan here it is again
Chassis Type: 4E0
Coding: 0007773
3 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 180787 km
Time Indication: 0
Freeze Frame:
RPM: 955 /min
Load: 31.4 %
Speed: 0.0 km/h
Temperature: 47.0°C
Temperature: 31.0°C
Voltage: 12.573 V
16692 - Cylinder 8
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 180787 km
Time Indication: 0
Freeze Frame:
RPM: 936 /min
Load: 27.4 %
Speed: 0.0 km/h
Temperature: 48.0°C
Temperature: 31.0°C
Voltage: 12.446 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 181023 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 21.0°C
Voltage: 11.303 V
Coding: 0000002
Coding: 0008597
Coding: 0410624
Component: ELV XXXX
Coding: 4071648
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 10
Reset counter: 136
Mileage: 180468 km
Time Indication: 0
Date: 2013.07.01
Time: 12:31:36
Coding: 0000103
4 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 104
Mileage: 181185 km
Time Indication: 0
Date: 2110.03.31
Time: 19:51:38
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 143
Mileage: 181111 km
Time Indication: 0
Date: 2013.07.28
Time: 00:12:02
Freeze Frame:
Bin. Bits: 01000000
Bin. Bits: 0000000
Bin. Bits: 001
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 119
Mileage: 180658 km
Time Indication: 0
Date: 2013.07.15
Time: 10:13:24
Freeze Frame:
Fault Priority: 5
Fault Frequency: 5
Reset counter: 39
Mileage: 180787 km
Time Indication: 0
Date: 2013.07.18
Time: 17:55:15
Coding: 1118545
Coding: 0143123
Coding: 00000034
Shop #: WSC 02313
Coding: 00139548
Shop #: WSC 02313
Coding: 0532707
Coding: 0012241
Coding: 0048263
7 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 125
Mileage: 180787 km
Time Indication: 0
Date: 2013.07.18
Time: 18:12:45
01304 - Radio
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 125
Mileage: 180787 km
Time Indication: 0
Date: 2013.07.18
Time: 21:07:18
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 125
Mileage: 180787 km
Time Indication: 0
Date: 2013.07.18
Time: 21:09:39
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 125
Mileage: 180787 km
Time Indication: 0
Date: 2013.07.18
Time: 21:16:10
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 125
Mileage: 180787 km
Time Indication: 0
Date: 2013.07.18
Time: 21:21:09
Freeze Frame:
Fault Priority: 3
Reset counter: 104
Mileage: 180787 km
Time Indication: 0
Date: 2013.07.18
Time: 21:25:32
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 125
Mileage: 180787 km
Time Indication: 0
Date: 2013.07.18
Time: 23:03:49
Coding: 0410624
Component: ELV XXXX
Coding: 0000000
Coding: 0015510
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 119
Mileage: 180658 km
Time Indication: 0
Date: 2013.07.15
Time: 10:12:11
Coding: 4071658
Coding: 0003477
Coding: 0032364
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 0
Mileage: 180976 km
Time Indication: 0
Date: 2013.07.23
Time: 12:31:24
Coding: 0048702
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 114
Mileage: 180623 km
Time Indication: 0
Date: 2013.07.01
Time: 20:50:27
Coding: 0000016
Coding: 0010111
Coding: 0032364
Revision: A32C0220
Coding: 0000532
Coding: 0000018
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 40
Mileage: 180264 km
Time Indication: 0
Date: 2013.06.30
Time: 14:59:35
Coding: 0000002
5 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 16
Mileage: 169512 km
Time Indication: 0
Date: 2012.12.23
Time: 20:27:07
Freeze Frame:
Fault Priority: 7
Fault Frequency: 11
Mileage: 169512 km
Time Indication: 0
Date: 2012.12.23
Time: 20:33:41
Freeze Frame:
Fault Priority: 7
Fault Frequency: 7
Mileage: 169512 km
Time Indication: 0
Date: 2012.12.23
Time: 20:33:52
Freeze Frame:
Fault Priority: 7
Fault Frequency: 7
Mileage: 169512 km
Time Indication: 0
Date: 2012.12.23
Time: 20:34:02
Freeze Frame:
Fault Priority: 7
Fault Frequency: 4
Mileage: 181185 km
Time Indication: 0
Date: 2013.07.31
Time: 15:00:58
Coding: 0032364
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 144
Mileage: 181120 km
Time Indication: 0
Date: 2013.07.28
Time: 13:27:04
Coding: 0232125
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 128
Mileage: 170388 km
Time Indication: 0
Date: 2013.03.19
Time: 10:06:55
Freeze Frame:
Speed: 17.0 km/h
Temperature: -1.0°C
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 802 C
Component: Türsteuer.HR BRM003 0100
Coding: 0032364
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 C HW: 4E0 919 283 C
Component: Parkhilfe 8-Kan H12 0030
Revision: 00H12000 Serial number: 08720528501057
Coding: 0201308
VCID: 23450610E2D856001D9
Address 77: Telephone
Cannot be reached
End ---------------------------------------------------------------------
Quick Reply: bluetooth Help
