How Do I Replace a Battery Management Module
Old Aug 6, 2016 | 07:52 AM
A8Pete's Avatar
Default How Do I Replace a Battery Management Module
If I replace the battery management module located just above the negative terminal of the battery do I need to code it into the management system using VCDS? If so how do I do it.
Many thanks
Old Aug 7, 2016 | 07:00 AM
A8Pete's Avatar
Does anyone know the answer to this one? Many thanks.
Old Aug 7, 2016 | 08:43 AM
haggisuk's Avatar
So you have Vcds?
If you do scan your current one
Replace module
Scan again
Check coding
Clear any faults
And assuming fully charged battery is fitted at same time code it so the car is starting off with a good charged known state
Old Aug 7, 2016 | 09:25 AM
A8Pete's Avatar
Originally Posted by haggisuk
So you have Vcds?
Replace module
Scan again
Check coding
Clear any faults
Thank you.
By scan the current one, do I need to go into module #61 and do a scan there? If so I cant do that as the VCDS returns module not responding hence why I may have to buy a new one and fit it.
Many thanks
Old Aug 7, 2016 | 10:02 AM
haggisuk's Avatar
Have a look at your old scan logs any coding info can be found there.
Tbh I can't remember if there is any coding to be done on them.
Have you checked the integrity of the little red wire on the battery post
Old Aug 7, 2016 | 09:06 PM
ScottCNelson's Avatar
Necromancer
Default EMM Procs
Many thanks
Attached. You will need to recode your battery SN afterwards.
File Type: pdf
Old Aug 8, 2016 | 01:01 AM
A8Pete's Avatar
Seems like I managed to get things working.
I had a whole bunch of errors relating to the engine management module. I could also not access #61 through the VCDS. Also the battery level on the dash board MMI was also reporting zero.
I knew the battery was OK.
I removed the battery and replaced it with one from another car. This seemed to reset everything and the dash MMI showing 100%. The errors disappeared and #61 became accessible via the VCDS.
I then put the original battery back and all seems well. I'll monitor things for a few days to make sure everything stays well.
Old Aug 8, 2016 | 07:58 AM
MP4.2+6.0's Avatar
Tech Guru
So simplified, disconnect battery, let it sit a while, then reconnect. I think Mister Bally ran into this with some module or other in the past too.
 Pouria Savadkouei
 Michael S. Palmer
Old Aug 8, 2016 | 08:28 AM
A8Pete's Avatar
Yep, spot on.
Alabutler
18
Nov 25, 2023 11:37 PM
Audi0609
12
Jan 27, 2019 09:20 AM
raaizin
Oct 13, 2016 11:02 PM
that_tg
14
Nov 11, 2013 09:16 AM
tilhas
A4 (B8 Platform) Discussion
13
Nov 30, 2011 01:29 PM
