Sponsored by:
Sponsored by:
Long Crank EPC and CEL on, codes?
Old 12-26-2016, 10:32 PM
jbrannam's Avatar
Default Long Crank EPC and CEL on, codes?
Background: we purchased this car 3 years ago with 109k miles, 1-owner always dealer serviced. It has been relatively problem free with the exception of a ESP/ABS/Parking Brake malfunction - which still exists, and a right front strut leak which we recently replaced. It presents a wheel speed sensor error, but attempted replacement of the sensor by two shops did not correct the problem. Last month at the end of the day the car cranked longer than usual and then idled roughly and stalled. EPC and CEL on. No improvement after a couple of attempts and driving a few blocks, so had it towed. A VCDS scan showed multiple codes, many signal to ground or open circuit. We observed the right HPFP was leaking. After replacement of the HPFP, the symptoms remained the same. Replaced the fuel filter, no improvement. Tonight we found the battery to be weak and replaced it. Afterward ran a VCDS and cleared DTCs. Still a longer than usual crank but the idle was smoother and the car didn't stall. EPC still on, but no CEL. After backing the car down the driveway it became apparent there was a loss of power, felt as it if it were bogged down. Returned home and ran another scan - posted below. Any assistance from those with experience/expertise in identifying potential sources and next steps in diagnosing this issue would be greatly appreciated!
Monday,26,December,2016,20:42:40:25739
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 16.8.4.2 (x64)
Data version: 20161129 DS267.0
Ross-Tech: Home
VIN: WAULV44E37N003657 License Plate:
Chassis Type: 4E (4L0)
Scan: 01 02 03 05 06 07 08 09 0E 0F 15 16 17 19 34 36 37 38 42 46
47 4F 52 53 55 56 61 62 65 67 6C 72 76 77
VIN: WAULV44E37N003657 Mileage: 264690km-164470miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: Malfunction 0010
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
0E-Media Player 1 -- Status: OK 0000
0F-Digital Radio -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
34-Level Control -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: OK 0000
38-Roof Electronics -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: Malfunction 0010
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: Malfunction 0010
67-Voice Control -- Status: OK 0000
6C-Back-up Cam. -- Status: Malfunction 0010
72-Door, Rear Right -- Status: Malfunction 0010
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine Labels: 079-907-560-BVJ.clb
Part No SW: 4E1 910 560 A HW: 4E1 907 560
Component: 4.2l V8/4V 0040
Revision: 71H16--- Serial number: AUX3Z0F6797979
Coding: 01060009190F0120
Shop #: WSC 26116 444 84545
VCID: 204FA42FF3A76842E9-8074
12 Faults Found:
001112 - Evap System Purge Control Valve (N80)
P0458 - 002 - Short to Ground
Freeze Frame:
Fault Status: 01100010
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 264694 km
Time Indication: 0
Date: 2016.11.18
Time: 17:00:40
Freeze Frame:
RPM: 183 /min
Load: 100.0 %
Speed: 0.0 km/h
Temperature: 4.0°C
Temperature: 6.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 10.795 V
005224 - EVAP Canister Solenoid Valve 2 (N115)
P1468 - 002 - Short to Ground
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 264694 km
Time Indication: 0
Date: 2016.11.18
Time: 17:00:40
Freeze Frame:
RPM: 183 /min
Load: 100.0 %
Speed: 0.0 km/h
Temperature: 4.0°C
Temperature: 6.0°C
Voltage: 10.922 V
005173 - Secondary Air Pump Relay (J299)
P1435 - 002 - Short to Ground
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 264694 km
Time Indication: 0
Date: 2016.11.18
Time: 17:00:40
Freeze Frame:
RPM: 183 /min
Load: 100.0 %
Speed: 0.0 km/h
Temperature: 4.0°C
Temperature: 6.0°C
Voltage: 10.922 V
004763 - Fuel Pressure Regulator Valve; Bank 2 (N276)
P129B - 004 - Open Circuit
Freeze Frame:
Fault Status: 01100100
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 264694 km
Time Indication: 0
Date: 2016.11.18
Time: 17:00:40
Freeze Frame:
RPM: 386 /min
Load: 100.0 %
Speed: 0.0 km/h
Temperature: 4.0°C
Temperature: 6.0°C
Voltage: 10.541 V
005634 - Power Supply Terminal 30
P1602 - 002 - Voltage too Low - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: -40.0°C
Absolute Pres.: 0.0 mbar
Voltage: 0.000 V
005715 - Please check DTC Memory of ABS Controller
P1653 - 008 -
Freeze Frame:
Fault Status: 01101000
Fault Priority: 0
Fault Frequency: 3
Reset counter: 255
Mileage: 264696 km
Time Indication: 0
Date: 2016.12.23
Time: 01:52:25
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 4.0°C
Temperature: 6.0°C
Voltage: 11.938 V
005494 - Right Engine Mount Solenoid Valve (N145)
P1576 - 002 - Short to Ground
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 264696 km
Time Indication: 0
Freeze Frame:
RPM: 183 /min
Load: 100.0 %
Speed: 0.0 km/h
Temperature: 4.0°C
Temperature: 6.0°C
Voltage: 10.795 V
005490 - Left Engine Mount Solenoid Valve (N144)
P1572 - 002 - Short to Ground
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 264696 km
Time Indication: 0
Freeze Frame:
RPM: 183 /min
Load: 100.0 %
Speed: 0.0 km/h
Temperature: 4.0°C
Temperature: 6.0°C
Voltage: 10.795 V
004199 - Intake Air Switch-Over Valve (N335)
P1067 - 002 - Short to Ground
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 264696 km
Time Indication: 0
Date: 2016.12.23
Time: 01:52:46
Freeze Frame:
RPM: 183 /min
Load: 100.0 %
Speed: 0.0 km/h
Temperature: 4.0°C
Temperature: 6.0°C
Voltage: 10.922 V
000258 - Mass Air Flow Sensor (G70)
P0102 - 002 - Signal too Low
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 264696 km
Time Indication: 0
Date: 2016.12.23
Time: 01:52:46
Freeze Frame:
RPM: 182 /min
Load: 100.0 %
Speed: 0.0 km/h
Temperature: 4.0°C
Temperature: 6.0°C
Voltage: 10.795 V
008852 - Fuel Pressure Regulator Valve (N276)
P2294 - 004 - Open Circuit
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 264696 km
Time Indication: 0
Date: 2016.12.23
Time: 01:52:47
Freeze Frame:
RPM: 386 /min
Load: 100.0 %
Speed: 0.0 km/h
Temperature: 4.0°C
Temperature: 6.0°C
Voltage: 10.541 V
009217 - EVAP Leak Detection Pump Control Circuit
P2401 - 002 - Short to GND
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 264696 km
Time Indication: 0
Date: 2016.12.23
Time: 01:52:55
Freeze Frame:
RPM: 805 /min
Load: 39.2 %
Speed: 0.0 km/h
Temperature: 5.0°C
Temperature: 6.0°C
Voltage: 14.478 V
Readiness: 0010 1101
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 4E1 910 156 C HW: 09L 927 156 A
Component: AG6 09L 4,2lFSI USA 0010
Revision: --H01--- Serial number: 4203722
Coding: 0000002
Shop #: WSC 02313 785 00200
VCID: 2345AB23E2B1735AF4-8076
1 Fault Found:
006231 - Load Signal
P1857 - 001 - Error Message from ECU
Freeze Frame:
Fault Status: 01100001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 264696 km
Time Indication: 0
Date: 2016.12.23
Time: 02:04:42
Freeze Frame:
RPM: 640 /min
RPM: 576 /min
RPM: 0 /min
(no units): 30.0
(no units): 31.0
Temperature: 19.0°C
T.B. Angle: 0.0°
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 B HW: 4E0 614 517 BC
Component: ESP 5.7 allrad H46 0510
Coding: 0008597
Shop #: WSC 02313 000 00000
VCID: 224BAE27FDAB7A52FF-8076
3 Faults Found:
18265 - Load Signal
P1857 - 000 - Error Message from ECU
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - -
00285 - ABS Wheel Speed Sensor; Front Right (G45)
012 - Electrical Fault in Circuit
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 L
Component: FBS AUDID3 H10 0190
Revision: 01904910 Serial number: AUX3Z0F6797979
Coding: 0410624
Shop #: WSC 02311 785 00200
VCID: 58BFCCCFEB77E082D1-800C
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
No fault code found.
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 D HW: 4E0 959 760 B
Component: Sitzmemory BFS H02 0010
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 4071648
VCID: 2447A83FE7BF74628D-8070
1 Fault Found:
00003 - Control Module
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 2
Fault Frequency: 1
Reset counter: 43
Mileage: 171820 km
Time Indication: 0
Date: 2013.07.30
Time: 16:22:53
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 731 K HW: 4E0 035 729 A
Component: Interfacebox H43 2740
Revision: 00000000 Serial number: 348FR067504390
Coding: 0000003
VCID: 2959B90B809DA90ABE-807C
Subsystem 1 - Part No: 4E0 910 611
Component: E0380 BedienteilH03 0040
Subsystem 2 - Serial number: 00000000012597
Subsystem 3 - Serial number: 0123.06.060000000100010116ÿ
Subsystem 4 - Serial number: 010116ÿ
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 B HW: 4E0 820 043 H
Component: KLIMAAUTOMAT 017 0450
Revision: 00000032 Serial number: 00000000100411
Coding: 0037185
VCID: 1C3790DFDFCF4CA235-8048
Subsystem 1 - Part No: 4E0 910 772 A
Component: Sitzluefter FS H02 010
Subsystem 2 - Part No: 4E0 910 772 A
Component: Sitzluefter BFS H02 010
Subsystem 3 - Serial number: 898053000
Subsystem 4 - Serial number: HO28062006065A000000000189ÿ†89
Subsystem 5 - Serial number: 000189ÿ†898053000 000-SHO
Subsystem 6 - Serial number: 000-SHO28062006065A00000000
Subsystem 7 - Serial number: 65A000000000184ÿ
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 Q HW: 4E0 907 279 Q
Component: ILM Fahrer H15 0230
Coding: 0143123
VCID: 366362774123F6F223-8062
Subsystem 1 - Part No: 4E1 910 113 B
Component: Wischer WWS D3 H50 0400
Coding: 00000036
Shop #: WSC 02313
Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH13 0090
Coding: 00139548
Shop #: WSC 02313
3 Faults Found:
00908 - Control Module for Wiper Motor
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 25
Mileage: 264695 km
Time Indication: 0
Date: 2016.12.23
Time: 21:27:38
01520 - Rain and Light Recognition Sensor (G397)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 25
Mileage: 264695 km
Time Indication: 0
Date: 2016.12.23
Time: 21:27:39
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 25
Mileage: 264695 km
Time Indication: 0
Date: 2016.12.23
Time: 21:27:38
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 F HW: 4E0 035 111 A
Component: CD-Changer H44 0470
Revision: 00000000 Serial number: AUZ5ZBF8148298
Shop #: WSC 00000 000 00000
Address 0F: Digital Radio Labels: 4E0-910-593-SIR.lbl
Part No SW: 4E0 910 593 D HW: 4E0 035 593
Component: SDAR SIRIUS H04 0670
Revision: 00000000 Serial number: AUZ4Z7F0013509
VCID: 285FBC0F9B979002A1-807C
1 Fault Found:
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 240
Mileage: 264696 km
Time Indication: 0
Date: 2016.12.23
Time: 02:04:41
Address 15: Airbags Labels: 4E0-910-655-94.lbl
Part No SW: 4E0 910 655 C HW: 4E0 959 655 J
Component: Airbag 9.41 H12 4030
Revision: 91H12400 Serial number: 0037Q0006YC2
Coding: 0532707
VCID: 2643B2379183867293-8072
Subsystem 1 - Part No: 4E0 910 339
Component: BF-Gewichtsens. H01 0030
Subsystem 2 - Serial number: 36FA4
Subsystem 3 - Serial number: 0001.01.0000H0100000000000ÿ†63
Subsystem 4 - Serial number: 000000ÿ†63328RB4014CF81FYÿ†63
Subsystem 5 - Serial number: CF81FYÿ†63428RB4014CF849Wÿ†63
Subsystem 6 - Serial number: CF849Wÿ†63528RB4014D11E1Fÿ†63
Subsystem 7 - Serial number: D11E1Fÿ†63628RB4014CF892Wÿ†63
Subsystem 8 - Serial number: CF892Wÿ†63729RB4015FD366Wÿ†63
Subsystem 9 - Serial number: FD366Wÿ†63829RB4015FDF72%ÿ
Subsystem 10 - Serial number: FDF72%ÿ
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549
Component: Lenksäulenmodul H14 0040
Coding: 0012141
VCID: 65C1F53BAC054D6A5A-8030
Component: Lenkradmodul H07 0090
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 951 C HW: 4E0 920 951 C
Component: KOMBIINSTR. VDO H82 0520
Revision: D03 Serial number: AUDID3F6001090
Coding: 0048263
Shop #: WSC 26105 444 100825
VCID: 2541B53BEC858D6A9A-8070
Address 19: CAN Gateway Labels: 4L0-910-468.clb
Part No SW: 4L0 910 468 HW: 4L0 907 468
Component: J533__Gateway H06 0040
Revision: 00H06000 Serial number: 0900B066178024
Coding: F5D5DF7F307A0E
VCID: 6CD7801F4FEF7C2205-8038
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 J HW: 4E0 907 553 F
Component: LUFTFDR.-CDC H06 6310
Coding: 0015510
VCID: 2A5B4607859BA212B7-807E
1 Fault Found:
01577 - Turn-Off due to Over-Temp
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 4
Fault Frequency: 1
Reset counter: 24
Mileage: 264696 km
Time Indication: 0
Date: 2016.12.23
Time: 02:06:09
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H02 0010
Coding: 4071658
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 C HW: 4E0 919 887 D
Component: MNS US H48 0960
Revision: 00000000 Serial number: 381FK067502181
VCID: 2E534A17B973CE326B-807A
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No: 4E0 910 135 A
Component: Dachknoten D3 H04 0090
Serial number: 00000617700031
Coding: 0003477
VCID: 1D319DDBC4D545AAC2-8048
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 801 B
Component: Türsteuer.FS BRM003 0100
Coding: 0032364
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 D HW: 4E0 907 289 D
Component: Komfortgeraet H07 0010
Revision: 00100007 Serial number: W040606260442
Coding: 0048702
Subsystem 1 - Part No: 4E0 910 853
Component: Heckdeckel H06 0060
Subsystem 2 - Part No: 4E0 907 719
Component: Neigungssensor H05 0020
1 Fault Found:
01504 - Bulb for License-Plate Light (X)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 3
Fault Frequency: 254
Reset counter: 240
Mileage: 249517 km
Time Indication: 0
Date: 2016.03.20
Time: 16:12:01
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 P HW: 4E0 035 223 F
Component: DSP-High D3 H02 0070
Revision: PROD_01 Serial number: 00000000002290
Coding: 0000026
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
Component: ILM Beifahrer H11 0070
Revision: Serial number: 00000000088543
Coding: 0010111
VCID: 1E339AD7C9D35EB2DB-804A
Subsystem 1 - Part No: 4E0 910 511 A
Component: UGDO HL US H04 0050
Subsystem 2 - Serial number: 0253440T15VK05
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 802 B
Component: Türsteuer.BF BRM003 0100
Coding: 0032364
1 Fault Found:
02126 - Central Locking Button; Exterior Door Handle
008 - Implausible Signal
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Reset counter: 201
Mileage: 258912 km
Time Indication: 0
Date: 2016.07.26
Time: 15:29:28
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 C HW: 4E0 907 801 A
Component: EPB A32C0220 H02 0220
Revision: A32C0220
Coding: 0000922
VCID: 1F4DA7D3CED957BAD0-804A
1 Fault Found:
01316 - ABS Control Module
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 3
Fault Frequency: 4
Reset counter: 24
Mileage: 264696 km
Time Indication: 0
Date: 2016.12.23
Time: 02:06:27
Freeze Frame:
Voltage: 13.66 V
Count: 236
Address 55: Headlight Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Revision: 00000001 Serial number:
Coding: 0000018
Subsystem 1 - Part No: 4F0 941 329 B
Component: AFS-Modul links H02 0020
Subsystem 2 - Part No: 4F0 941 329 B
Component: AFS-Modul rechtsH02 0020
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 M HW: 4E0 035 541 P
Component: TUNER EU/US/RDW H42 0570
Revision: 00000000 Serial number: 396FR067541314
Coding: 0000002
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H12 0550
Revision: 00000000 Serial number: 00000000011552
Subsystem 1 - Part No: 4E0 915 105 A
Component: von VA0 2606260368
Coding: 344530393135313035412056413032363036323630333638
Shop #: WSC 00000 128 00289
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 801 C
Component: Türsteuer.HL BRM003 0100
Coding: 0032364
Address 65: Tire Pressure Labels: 4E0-910-273.lbl
Part No SW: 4E0 910 273 A HW: 4F0 907 273 A
Component: Reifendruck 3 H05
Revision: 00050340 Serial number: 00000900046386
Coding: 0232125
1 Fault Found:
01299 - Diagnostic Interface for Data Bus (J533)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 25
Mileage: 264696 km
Time Indication: 0
Date: 2016.12.23
Time: 00:05:30
Freeze Frame:
(no units): 255.0
Voltage: 0.00 V
(no units): 27.0
Temperature: 0.0°C
Temperature: 0.0°C
Temperature: 0.0°C
Temperature: 0.0°C
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 Q HW: 4E0 035 753 A
Component: SDS 3501 US H45 0630
Revision: 00000000 Serial number: 00000606090173
Shop #: WSC 12336 024 394758
VCID: 3467587F575FE4E21D-8060
Address 6C: Back-up Cam. Labels: 4E0-910-441.clb
Part No SW: 4E0 910 441 HW: 4L0 907 441 A
Component: J772__Rearview 0050
Revision: --H12--- Serial number: 525PA8-J66102H
Coding: 1120402
VCID: 5CB7D0DF9F4F0CA2F5-8008
1 Fault Found:
00778 - Steering Angle Sensor (G85)
Freeze Frame:
Fault Status: 01101101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 240
Mileage: 264696 km
Time Indication: 0
Date: 2016.12.23
Time: 02:04:40
Freeze Frame:
Term 15 On
Reverse OFF
Count: 3
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 802 C
Component: Türsteuer.HR BRM003 0100
Coding: 0032364
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 14
Reset counter: 201
Mileage: 262928 km
Time Indication: 0
Date: 2016.10.07
Time: 16:05:36
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 C HW: 4E0 919 283 C
Component: Parkhilfe 8-Kan H12 0040
Revision: 00H12000 Serial number: 08720617900398
Coding: 0221208
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4F0 910 336 D HW: 4E0 862 335
Component: Handyvorb2 H13 0700
Revision: 00000000 Serial number: 00000007535131
Coding: 0010900
End-------------------------(Elapsed Time: 03:51)--------------------------
Old 12-26-2016, 11:17 PM
haggisuk's Avatar
The fact that most of your problems relate to engine management control circuits then I would be looking at the connection at the ecu and the harness running out from there.
Most of the faults relate to control of the engine. main ones that effect running of engine are the Maf and fuel pressure regulation.
by default the fuel pressure regulation defaults to lower pressure when there is no control signal which would allow for idle but wouldn't be enough to run at higher RPM
your other fault that you mention on wheel speed sensor is likely to be bad wiring back to abs unit and has been experienced by a few board members and a search should find them when you get passed the problems of engine management.
Old 12-27-2016, 05:32 AM
97urS6's Avatar
Regarding your ABS speed sensor issue, I just went through the same issue, you can look up one of my latest threads on that for details. But to summarize, if it is not the sensor, it is either the wires at the connector (check inside the connector carefully for a broken wire). If that looks good, then pull the big connector on the ABS Module, map out which pin (need wiring schematic from Bentley) leads to the specific sensor your getting the error on... check for continuity on the wire from the ABS connector to the sensor connector. If that is good then it is the electronic portion of the ABS unit... I recommend only changing the electronics side of the whole module, as pump is probably fine... that will save you from bleeding brakes, which can be an arduous process. Used ABS modules are fairly inexpensive, as the dealer price is outrageous.
Old 12-27-2016, 03:43 PM
jbrannam's Avatar
Thank you both for your quick and helpful advice. I've spent hours researching the issue so far and we've looked for evidence of water and wiring damage but will give the ECU a closer look. The post with the most nearly identical codes turned out to be corrosion in a fuse contact but we found no evidence of that. It can be so difficult finding the culprit!
Old 12-28-2016, 10:18 PM
jbrannam's Avatar
Default Help with advanced measuring values
Spent some time trying to learn more about vag-com to better diagnose this issue. Can anyone help with group info and values? Maybe suggest a specific group number?
I scanned through the measuring blocks and advanced measuring values and found a couple things odd. For example group 60 electronic throttle showed 12.9% throttle valve sensor 1 (g187) and 87.5% throttle valve sensor 2 (g188), is that disparity normal? Also every value I saw for mass air flow sensor (g70) was 0.00 g/s???
Symptoms remain, long crank, idling alright, bogs and acts like it will stall when given gas, EPC on, no engine light.
Any help would be very much appreciated!
Old 12-29-2016, 12:02 AM
MP4.2+6.0's Avatar
I'm not really following the details here or trying to parse the nuances of the VCDS. Agreed it could be wiring or ECU itself. Also put on the list the fuel pump(s) back in the tank. From the description, sounds like it could be the main pump (as opposed to the extra transfer pump also back here). I have a sense sometimes folks/mechanics/maybe even dealers sometimes don't remember there are still tank pumps back there even with the HPFP's up front. Thus, you might want to search on the variety of posts and typical symptoms for the tank pumps, whether FSI motors or older ports. Remember FSI 4.2 set up for this purpose is close enough to the many Audis out there with it--Q7 4.2, C6 A6 4.2, S5 4.2's, S4 4.2's--for any posts to be searched with similar symptoms.
Old 12-29-2016, 01:28 AM
haggisuk's Avatar
The readings from the throttle are normal. as it sweeps the readings will come together at mid throttle and go opposite what you have at idle when full throttle is applied.
like I said before your two main things that jump out at me are the Maf reading 0 and no control over fuel pressure regulation which pertains to the high pressure rail.
it may well be wiring harness or ecu connection like mentioned before or it may be a 12v supply problem .
you need to study the wiring diagrams and check basic things like wiring integrity supply voltages etc and see what is missing.
use the following thread as a guide of how to go about the checks in conjunction of looking at the wiring diagrams
Testing - Open Circuits, Short to Ground or Positive, etc....
Old 12-29-2016, 03:40 AM
Mister Bally's Avatar
Remember that there is no VCDS code for "running out of fuel" so if the primary fuel pump is bad, as in no motor spin when 12 volts is applied, there is no code whatsoever.
I had the old 30 seconds of running after starting then a stall issue recently. Very consistent. No code present. I use standard automotive troubleshooting techniques to determine it was the fuel pump.that was defective. Actually found a VDO pump at Auto Zone that was 24/7 on a Sunday morning at 2:00 am.
Old 12-29-2016, 04:09 AM
haggisuk's Avatar
check SC 5 fuse (15Amp)
SC is Passenger side fuse panel at the end of the dash, assuming your driving a left hand drive car
Old 12-29-2016, 06:48 AM
jbrannam's Avatar
I have found many posts with fuel pump issues that presented similarly. I probably tend to over-research and overwhelm myself LOL. Visual inspection, including the ECU/ECM and fuse 5, did not show anything obvious. Will further investigate fuel supply & electrical. At the outset the car did want to stall after being started but currently idles indefinitely (sounds a little off) and will only bog when given more fuel. Again thank you for the advice/expertise!
Quick Reply: Long Crank EPC and CEL on, codes?
