Need help with air fitting on air strut
Old Oct 22, 2012 | 05:08 PM
jmhjgh's Avatar
Default Need help with air fitting on air strut
Hello all, what is the fitting on the air strut that the air line connects to? Is this a check valve? The threads on mine broke (see picture) and I am wondering 2 things: 1. Where can I can get a new one. 2. The air line fitting is the same thread size: can I just screw the air line fitting in while I wait for a replacement part?
Old Oct 23, 2012 | 12:13 PM
jmhjgh's Avatar
Looks like you can only get that fitting with the strut.
Old Oct 23, 2012 | 12:30 PM
mishar's Avatar
Tech Guru
That should be a check valve. It is there to keep a minimum pressure in the strut. They say it can be damaged if pressure goes lower than that. Since it is already broken you have nothing to loose. Try screwing line directly.
That one can be repaired by some custom treading.
Old Oct 23, 2012 | 01:28 PM
jmhjgh's Avatar
It is unfortunate that the male portion broke off. Do you know what size threads they are? It seems like an M8 diameter. I was wondering if I could silver solder it back together?
Old Oct 23, 2012 | 03:46 PM
Mister Bally's Avatar
Just replace it with a Metric fitting and replace the mate on the tubing if necessary.
Old Oct 24, 2012 | 06:32 AM
jmhjgh's Avatar
I ended up threading the stock air line fitting into the strut. However, if it is a check valve with regulator it would be nice to know what pressure it is set at. It can't be a true check since there would need to be both intake and exhaust. Looking at the inside cavity, it looks like they drilled 4 small holes around the outside but I am not sure if there is a ball and spring inside.
Old Oct 24, 2012 | 07:01 AM
mishar's Avatar
Tech Guru
I believe you can find a few words about it here.
It can be there to prevent fast discharge if the line is broken. Air has to go both ways in order to regulate height.
ECS Tuning-Audi
A4 (B8 Platform) Discussion
21
Sep 11, 2021 04:04 PM
sbcrazy
Sep 9, 2015 04:43 AM
ZPA117
Sep 8, 2015 11:55 AM
ECS Tuning-Audi
A4 (B7 Platform) Discussion
Sep 1, 2015 09:16 AM
ECS Tuning-Audi
Sep 1, 2015 08:27 AM
