Suspension issues 2006 A8L- revised, please help!
So I figured out the control head for the suspension was replaced and not coded. Once it was coded, I got all the suspension options back in MMI. The issue is that now the car wont stay lowered when set to dynamic. There is a lot of wheel gap. If I set to lift mode, the car lowers first, then pumps up. If I go from lift to dynamic, it will lower, then gradually pump back up to roughly the same height as lift. My car has sport suspension.
Also, I have an adaptive headlight error that appeared when the control head was coded by the shop. I feel like maybe the suspension needs calibrated because there's no reference point set currently which caused the adaptive headlights to be all wonky as wellwell. Am I wrong? I had a shop that specializes in VAG do this work for me and I don't think they calibrated the suspension. They recommended I pull the fuse for the headlight error. They told me that the ride height was normal, but it's very noticeably jacked way up in the front. Also, I never see the green down icon appear or the down arrow highlight when going 75+ in dynamic.
Baloo588
11
06-24-2012 08:45 AM
M3KILR
11-07-2004 06:45 PM
BiturboBoy_V2.0_S3--
11
09-26-2001 04:45 PM
