MMI/nav updates
#21
Are you guys really sure Audi Connect w/ the Google overlay is even updating the maps? I have my doubts it does anything but paint pretty aerial overlays on the screen, plus feed street view here and there. That is, when it starts, you see the baseline car map, and then over a few minutes (w/ a good connection) the photo layer gets integrated.
Has anyone specifically tried an area with known road construction changes to see what happens if you toggle back and forth between Google Earth and baseline maps? That would be the acid test it seems to me.
Below is what the MMI manual says. Sounds like a layer to me, not a replace. BTW, back to my earlier reply, Connect in this context (w/ Google Earth) is not what I was describing on the C7.5's. There the base map layer stored on the drive is being updated if done either OTA or via conventional download w/ the files on a stick.
#22
Your idea about the system seems much more likely. I know I have the option to switch between the two, but without connect, only the color of the overlay changes, and no satellite coverage.
so I need to figure out how to update the base map
#23
GreekDeno
05-01-2014 01:49 AM
ESN
15
09-27-2007 07:05 PM
markcincinnati
01-15-2007 03:53 PM
