need some torque specs quick, left the bentley at home
on the 2.2 5cyl, i need the torque for the head bolts, cam holder downer nuts and the valve cover nuts. also, we just broke a stud on one of the cam clamp jobs, i dont know what its called. cam bearing maybe? any thoughts on that? i do have a whole head for parts right here
you gotta get that stud out.
if there's and threads left on it, try to put two nuts on it and take it out that way. Otherwise, vise grips should do it.
I'll get back to you on the head bolt specs..down in the garage.
ROCKETAUDI< ROCKETAUDI ROCKETAUDI...
...Bearing Caps for cam shafts are as follows per Bentley...
lubricate bearing surfaces and camshaft journals
install caps in proper order (from the front of the head it goes 1,2,3,4)
first lightly tighten nuts of bearingcaps 2 and 4 diagonally
then tighten all nuts to 20Nm (14 ft lb)
Re: ROCKETAUDI< ROCKETAUDI ROCKETAUDI...(head bolts)
...I hope this works. Per Bentley...
Rock this is goona be tough but I'll do my best.
9__5__3__1__7__11
12__8__2__4__6__10
This is your head looking down at it. the side that starts with 9 is the Manifold side, THe side that starts with 12 is the spark plug side of the head. this is the order you should tighten your head bolts. 1-40Nm (29 ft lb)
2-60 Nm (44 ft lb)
3- additional 1/2 turn (180 degrees)
further in one movement (two 90
degree turns are permissible)
9__5__3__1__7__11
12__8__2__4__6__10
2-60 Nm (44 ft lb)
alrightroad
Audi allroad
12-14-2008 04:08 AM
Rolf
04-18-2007 12:40 PM
Mr.D-'97 A4q 12v
12v V6 Discussion
13
08-29-2004 11:49 AM
