hey guys i got a few questions
heres the deal this time. i bought a greddy profec electronic boost controller so i can run 14 psi. i dont have a line plugged up on top of my wastegate. i do have the spring and the bpv already. now to the question.
1.for a source of vacuum would i use the left top side of the wastegate actuater? or do i have to pretty much get rid of it?
im sure there is more questions i have but i dont remember right now to early.
i got a line to run the boost gauge
but i need to know which one to use for the valve? anyone know? i know one side is good vacuum from somewhere and the other goes to the wastegate cap. do i need to put the 1.8 bar spring in now? thats my other question. also i know i need to put the bpv in ill get that in sometime. after i get the bung welded on to the charge pipe.
is the one to the mani on the bottom
if so this is the line ill use. im hooking up an electronic boost controller. one side of the wastegate controller on this setup uses a strong vac line to actuate it then the other side goes to the wastegate cap.
got it hooked up and it works great
no new spring and it pulls 11 no problem. now i do have one question is it supposed to jerk when it gets over ten or is this the fuel cut coming in? see im not sure i even have one since it is an 85 euro 200.but after 10 it wants to jerk alittle. im going to put in the bpv soon i think ill run without the ebc for a while till i get that and the starter and the new fuel pump all in. it runs good has no boost issues no loss no spiking.that i know of at any rate. ill let you guys know.
mcorrow
16
02-24-2006 05:12 PM
StevenH
Performance and Tuning
06-02-2003 06:12 PM
Digit@lex
19
02-07-2003 02:45 PM
HDClown
05-07-2002 06:32 AM
