running cold continued, would the fan come on if thermostat
Old 11-21-2006, 06:11 AM
Member
qpower's Avatar
Default running cold continued, would the fan come on if thermostat
was stuck open? guage gets just out of the cold mark then goes down below after a few minutes of driving(as if the thermostat was operating properly)i get good heat but guage is buried in the cold . and when i got to work the radiator fan did come on . I dont wanna replace a good part so any guesses.
TIA 1990 200 TQ
Old 11-21-2006, 06:19 AM
jurq's Avatar
can you test resistance of the sender?
Old 11-21-2006, 06:37 AM
Kneale Brownson's Avatar
Default Re: running cold continued, would the fan come on if thermostat
As noted before, your gauge may not be accurate because of either a problem with your instrument cluster or your multifunction temperature sensor.
If all your coolant hoses get hot when the engine is fully warmed up and if the fan comes on appropriately (like after you stop driving or when sitting in traffic idling), your coolant is reaching proper temperatures. You are not "running cold", your gauge is not giving you an accurate reading.
Old 11-21-2006, 06:53 AM
audiqv8's Avatar
Default Are you getting heat in the cabin??
Turn the climate control to HI and see if the heat output is hot!!!
Old 11-21-2006, 02:30 PM
devesvws's Avatar
Default mine stays at the 3rd mark most of the time
the fan comes on when it gets just past the first single mark only. never gos past that point.i do have good heat coming out of the vents but it takes a few min longer than i think it should. i orderd a tstat from audi and new hoses to instal. i did replace the radiator from a parts car a few weeks ago and i know this is not right it should get hoter than that. i dont recall it runing so cool until i had the radiator bust a few weeks back. it has geting colder here but still it should run hoter hope i am on the right track any ideas? (o\/o) devesvws
Old 11-21-2006, 02:43 PM
Member
qpower's Avatar
Default cabin heat works well radiator hoses get hot , the one that connects to
the thermostat gets warm but not as hot as the other hoses and the fan came on appropriatly
thanks guys.
Old 11-21-2006, 04:43 PM
rooster 2's Avatar
Default It is not unheard of to buy a new thermostat that is defective........
with engine having warmed up, and one radiator hose hot to the touch, while the other radiator hose only warm to the touch leads me to think that the thermostat is stuck in the open position. Sounds like it is not opening up when coolant temp reaches around 180 to 190 degrees. I don't think the replacement radiator is the problem.
Old 11-21-2006, 07:32 PM
Chad T's Avatar
Most of these t-stats fail in the open position. The main symptom of that would be that the temp drops when moving/driving on the highway. Temp should come up if the car is just idling. Does your guage fluctuate like this or is it always reading cold?
Best way to tell for sure would be to pull up the coolant temp on the climate control head.<ul><li><a href="http://quattro123.com/Audi200ClimateControl.htm">http://quattro123.com/Audi200ClimateControl.htm</a</li></ul>
EuroVWGTi
12v V6 Discussion
9
08-04-2007 12:30 PM
gg117
15
07-22-2005 11:19 AM
CheeseHead Cubs Fan
10-01-2004 12:30 PM
4000skq
11-01-2003 07:05 PM
90qttro
02-10-2003 08:50 PM
Quick Reply: running cold continued, would the fan come on if thermostat
