For Oil leaks on a 12 v 2.8L V6 engine, some info please:
#11
Re: "RaceWare" are "head bolts"! Replacements for the stock, stretch bolts.
<center><img src="http://www.raceware-fasteners.com/RThsk1.gif"></center><p>Actually their head studs. Reusable too!
Expensive, but "The Best"!<ul><li><a href="http://www.raceware-fasteners.com">http://www.raceware-fasteners.com</a</li></ul>
#13
Re: Is it OK to just let it leak? Depends?
On how bad its leaking.
It will only get worse over time.
If its really bad, it can damage the clutch disk.
Requires the gearbox to be removed to change.
Often done when the clutch is done, even if its not leaking, because its better to do then, instead of "have to do" later. ;o)
Especially since the cost to R&R will be the same as a clutch job in labor fee's.
sconney
Audi Original "S" Cars
10-22-2003 09:45 PM
drhaller
06-07-2002 08:34 PM
