There is a leak on this thing .. i believe this is the oil cooler??
<center><img src="http://pictureposter.audiworld.com/42826/pump.jpg"></center><p>Could this be gasket issue? If it is how to replace it...Or how to remove from the oil pan?
That's the lowest point, could also be...
...head gaskets - common on the 2.8. Also check the crank position sensor on the side of the block just behine the cooler; mine had a leak there.
Re: I had a similar problem...I know oil was dripping off of that..
Which gasket, oil cooler or gasket somewher else?
Did you get yours replaced? Or should I worry about it too much or just top oil when needed. It's just a little annoying to see those wet spots tdown there...
Re: There is a leak on this thing .. i believe this is the oil cooler??
Man, that looks just like an oil cooler on a 2.1L wasserboxer engine in a Vanagon. I bet they are both VW parts.. hmmmmm... if that's the case, there's an o-ring inside that likes to give or the nut inside works loose (no, not you!). Take off the oil filter and look inside. Tighten the nut and see if that helps. You want to consider taking it off to inspect the o-ring and perhaps replace it.
Good luck.
Good luck.
Alpine 87.5
13
06-14-2004 09:40 PM
