Will it be big problem if the cam mark and crankshaft mark are a little bit offset?
and how to deal with that?
<img src="http://img15.imgspot.com/u/06/266/20/f1url1159145216.jpg">
<img src="http://img15.imgspot.com/u/06/266/21/fig2url1159146226.jpg">
This is the least offset I can get with the 2084 in the position.
<img src="http://img15.imgspot.com/u/06/266/21/fig3url1159146330.jpg">
(edited) The cam shaft mark should be level with the top of the cover gasket...
You should look through the window in the bell housing for the crank mark not that mark on the front of the engine. It can and should be perfectly lined up. Use the 2084 only to tighten it, it dosn't need to be on other then that. I guess I have not used the true 2084, maybe it does line the crank mark up when it is attached??
Jim Bush
Holland, MI
Jim Bush
Holland, MI
I never use that mark....
I only use the dimple on the rear of the camgear and line it up with the top of the valve cover. For the crank I look at the bellhousing area and find the proper timing mark. If and when they line up, voila!
secreTTasianman
09-13-2005 12:44 PM
ddg=shinebox racing
Inline-5 Discussion
12-05-2004 08:51 PM
DolphinA4
08-05-2002 02:05 PM
