RS3 Sunroof rattle
#11
My 2017 S# was replaced because of these roof rattles, and I upgraded to the 2018 RS3, but I have the same god damned rattles in this one as well!
This is driving me crazy!
I am thinking about lubing the rubber on the roof wherever it comes in contact with rubber on the body. Any materials I should avoid?
Do you read the posts above?The roof frame needs replacing. If you want to get rid of the noise take it to the dealer and get them to replace it under warranty. If you lube it up or anything else then its a temporary fix. I had the problem, it was fixed. No noise anymore. Thats the solution.
#13
This was from the Q7 TSB (and I did have the problem too), maybe the same TSB fix will work on the S3/RS3... worth a shot:
https://www.audiworld.com/forums/q7-...nroof-2692289/
