Top view camera select and making it default
#11
The left part of the screen is the rear camera view...that part I'm fine with...my complaint is the same as the original poster in that the right part of the parking assist screen does not stay on the 360 top down camera view...I set it to camera it reverts back after some time to just the graphic view of the sensors...for no rhyme or reason it seems...
#12
#13
Thanks I just wanted to clarify...you had said rear camera view so that's why I got confused...any help would be greatly appreciated
#14
I did this when I got my A5 2 months ago and it is my default also.
#15
I thought I had the same issue, turned out the location I was making the change was not correct. I'll have to look in the setting to determine what I changed. I do recall selecting the parking assist button then using the dail to access one of those side menus.
#16
Here you go - when in reverse and the camera comes up, shift the MMI wheel to the right to bring up this menu then change this setting to camera
For the OCD people (including me) sorry for the dust/crap that's showing - that's the problem with direct sunlight!!
#17
Yup, that's what I have been doing...and just like the OP said, after a certain period of time or a few cycles it goes back to graphic...
#18
#20
Only thing I can think of is if you use different keys - maybe this is a setting stored to each key? I use only one key since I got the car so not sure
