MIL light & Codes
Code - Possible Cause
Description of code
P1557 - Boost Leak?
(static) Turbo boost sensor (A) circuit value above upper control limit
P1139 - Clean MAF or EVAP can purge valve?
(intermittent) Long term fuel trim add. fuel bank 2 system too rich
P0175 - MAF? Air Filter? Clogged suction jet pump?
(static) Fuel trim, bank 2 System too rich
P1137 - O2? MAF? EVAP purge valve?
(intermittent) Long term fuel trim add. fuel bank 1 system too rich
P0172 - MAF? Air Filter? Clogged suction jet pump?
(static) Fuel trim, bank 1 System too rich
P0300 - Upstream or Downstream 02? Coil packs?
(intermittent) Random/Multiple cylinder misfire detected
P0306 - Fuel filter or coil packs?
(intermittent) Cyl 6 misfire detected
P1602 - Weak battery?
(intermittent) Power supply terminal 30 Low Voltage
P0455 - Gas cap?
(static) EVAP emission control system (Gross Leak) Leak detected
P1127 - Vacuum leak or MAF?
(intermittent) Long term fuel trim mult Bank 1 system too rich
P1129 - Vacuum leak or MAF?
(intermittent) Long term fuel trim mult Bank 2 system too rich
Looking like most of the codes were easily addressed, but they're still seeing the Gross EVAP leak and the turbo boost sensor issue now. They're going to smoke test it for leaks & I'm still hoping for a cheap & easy fix!
Anyone been in a similar situation an have an idea wat I can expect?
:: www.ECStuning.com :: Now with EXTENDED Customer Service hours!! | FIND US ON FACEBOOK!!
Phone: 1.800.924.5172 - Sales: 8:30am to MIDNIGHT EST | Customer Service 8:30am - 8pm EST
Questions? PM us for a quick response! | Email: Pete@ecstuning.com
Description of code
P1557 - Boost Leak?
P0455 - Gas cap?
