Turbo removal question
I always wonder how on earth you remove the turbos from the allroad 2.7t. I just happen to view the instructions on the Bentley DVD and noticed that the instruction say "Remove Engine"
Is there another way...say transmission out or something. If true, what a bad design. Removing turbos from 1.8t is easy as 123.
Pretty much everything requires engine removal. Heads? Remove engine. Windshield washer fluid ran out? Remove engine to fill.
Thanks
I guess because the v is so wide. They really only care about making the car and sell it anyway.
For example, inserting the crankshaft lock pin when changing the timing belt is a real PITA. (doesn't matter what you remove...) and then the combi valve on the passenger side that has to be removed before you remove the valve cover.
I can imagine hearing the voice of someone at the end of a big board-room table saying, "it's easy for us...let them worry about that", shall we continue with the design please...
jwktn
16
10-17-2007 05:45 PM
trackonly
12-12-2006 04:45 PM
BS4
03-04-2003 03:14 PM
