Where to Jack with Floor Jack
Hi All,
I would like to use a floor jack to lift my car at all four corners and put it on jack stands. Obviously I can't use the jack points for both, so I need to know where else I can safely lift the car? Any diagrams or pictures would be ideal, thanks!
This is such a crazy thing, when I first got my Allroad, I searched many forums for tips on this. Nobody wanted to tell me what would work, seems like everyone is scared of being sued for an "opinion"
I used a block of wood, and jack, to jack it from the front sub-frame, for the rear, I used a block of wood, and sometime no block of wood, to jack it from the center of the rear differential. Support with good jack stands at jack points at the pinch weld, or rectangular piece of metal protruding from beneath all side doors.
Be careful, as I know I would, for 2 tons on your head = dead. Oh yeah, use jack mode also by holding the "up" and "down" buttons at the same time for 5 to 10 secs, to activate "jack mode" .... then your car is totally jackable.
I wanted the car on jack stands to flush & bleed the brakes quickly at all four corners, but I ended up doing one corner at a time with the screw jack (car in jack mode and with wood blocks for safety). I read elsewhere not to use the rear diff as a jacking point, and I just didn't see anywhere else in the rear to safely lift at.
Always Overcharged
Audi A3 / S3 / RS 3
11-14-2006 02:02 PM
fourwheelslide
13
03-21-2005 08:50 AM
Oettinger_A4
12-10-2003 08:14 PM
