my serp. belt keeps skipping teeth...
my new serpentine belt tensioner is giving me a headache. First of all, it's noisey. Second, it's doing something weird because my serp. belt keeps wanting to come off!
Any suggestions, other than not drive it until I get it fixed?
Thanks,
Paul
Thanks,
Paul
was it noisy before it was replaced?
it may be the wrong belt. The tensioner bearing could be bad causing the noise, and if it is bad enough, cause the belt to wander off the pulley.
Did you remove any of the pulleys?
The hydraulic pump pulley can be put back on backwards. Causing it to be off by about 1 or 2 teeth, maybe something like that is throwing the belt off. Just a thought. Emmett
