wow! what a difference new engine mounts can make... can do..
it is most certainly noticeable from engine start up, launching from 1st and shutdown.. It cured those annoying vibration. Driver side was easy and fairly accessible - just have to manuever getting the mounts in and out. The passenger side was the biotch since you have to remove a lot of stuff that's in the way. Not a fun side..
That is all..
That is all..
I recommend the passenger side be changed when the turbo is done on higher mileage cars.
It won't ever be any easier to get to it...
unless you're Hap, Dave S, Brian W or Cody and you change turbos like normal folks change their underwear.
Re: What did you have to remove on the pass. side?
I removed the airbox top and bottom assembly to gain access to the top nut and from underneath, crossover pipe and turbo to xover hose. I also had to undo the starter wires/cable b/c it was on the way. Putting the pass side mount was a challenge for me which involved swearing and yelling which is not highly recommended .
2001s4loored
10-30-2007 07:41 PM
thewatcher101
07-19-2007 11:52 AM
inliner311
16
12-18-2006 06:23 PM
s4twin
13
04-24-2006 09:12 AM
Richie-S4
16
03-27-2004 06:24 PM
