Audi Q8 Discussion forums for the Audi Q8 SUVs
Q8 - OBDEleven
Old 05-28-2021, 01:35 AM
  #621
Dario Campolattaro's Avatar
Originally Posted by kirktx
I will PM you the phone number of the coder. As for a video search the Q8 forum for a post titled
Enabled Matrix light! Really cool
Inside the post you will find some photos and an actual video of the lights in action on an RSQ8. As far as legality they have not been approved by the NTSB to have a dealer encode, but there is no reason IMHO why they haven't. It is actually safer than without them encoded. You will need Matrix headligths, a Windows laptop and an ODIS for this feature to be encoded.
Thank you! I already traded text with him. I appreciate your help.
kirktx (05-28-2021)
Old 05-28-2021, 04:37 AM
  #622
kirktx's Avatar
Originally Posted by smfsh
Any chance I could get that info as well?
It does not appear you have Private Message enabled. I couldn't PM you.
Old 05-28-2021, 06:14 AM
  #623
retom's Avatar
Originally Posted by Dario Campolattaro
I think I'm going to do it. Just need to order the tool.
Do they do all the pictures and text at the upon turning on? Do they have the bight lane feature when on a highway?
Nope. Only the latest generation of matrix headlights in the e-tron and the e-tron GT have these functions.
Old 05-28-2021, 06:29 AM
  #624
retom's Avatar
Originally Posted by 1stRS
I was trying too. The directions several posts ago does nothing for my car.
Did you try this?
Module 09, Long coding, light_scenario, not active
or
byte 10, bit 0, disabled.
Old 05-29-2021, 06:03 AM
  #625
Longbird's Avatar
Can you remove the rev limiter? I think I saw a reference to one of the obdii letting you lower the air suspension. Anyone know which one?
Old 05-29-2021, 02:33 PM
  #626
retom's Avatar
Originally Posted by Glacier6
Alright, so I tried this and it’s still saying the RLS Night Sensitivity does not have any items. I can go into adaptations and click on it but there are no values after doing so.
is it possible this is just not available on the Q8?
Try security access code 31347.
Old 05-31-2021, 06:40 AM
  #627
Glacier6's Avatar
I finally got this activated. Never realized where you needed to enter the security access code so once I found that and entered 20103 it finally activated those settings in adaptations. I set it at 100 for day which appears to be the minimum and 1600 for dawn which appears to be the max.
We’ll see how much longer they stay on now...
Old 05-31-2021, 08:27 AM
  #628
retom's Avatar
As I remember, "down" is the value of lux to turn on the low beam in the dark so if you want to delay it it should be lowered and "day" is the value of lux to turn off the lights so if you want to have it earlier this value should be increased.
Old 05-31-2021, 10:09 AM
  #629
TahoeGator's Avatar
This thread was started in 2018 and some of the references are out of date. For someone wanting to do this in 2021, which OBDEleven controller is recommended? (For an RSQ8 if that matters). Thanks!
Old 05-31-2021, 08:26 PM
  #630
1stRS's Avatar
I have OBDeleven Pro, That’s probably your best bet. Some of the adaptations work, some don’t. MAKE SURE YOU TAKE YOUR TIME AND BACK UP EACH CONTROLLER. To do that, you need to visit each controller and select “Backup”. It will take a while to do all of them, but it will save you a costly trip to the dealer.
I also have OBDApp to lower the RSQ8. Aside from this adaptation, OBDeleven is very superior as it allows you to do everything yourself via adaptations or coding and you there’s also “Apps” you can purchase that are one touch adaptations/codings.
Quick Reply: Q8 - OBDEleven
