C6 Avant with MMI Issues
The MMI on my 2008 A6 Avant started working intermittently about two and a half months ago, then stopped completely (no lights at all on the buttons. Stealership identified that the amp was the victim of the dreaded leaking wiper hose and for $3k would replace the hose and amp. I had them replace the hose for $500'ish and sent the amp to Paulison for repair. By the time that the amp came back, the car had sat long enough that the battery had drained since I don't drive the car much (yes I did have the fiber ring in place). Couldn't recover the battery so I purchased a new Varta from the stealership for $275 and coded it with VCDS. All should be well; however, the MMI will not power up and I've tried the manual reboot process.
I've searched the forums but have found little information that could help and am hoping that someone can shed some light. Here is the information from the scan that I pulled this morning after having driven the car for a week since replacing the battery and coding it. The one known issue that I have is that the left side adaptive light is bad (i'm too cheap to have replaced the headlight just to have the bulb turn with the wheel and clear the code at this point).
Tuesday,11,June,2019,11:13:44:59173
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 19.6.0.2 (x64) HEX-V2 CB: 0.4505.4
Data version: 20190529 DS308.0
www.Ross-Tech.com
VIN: WAUKH74F08N026487 License Plate:
Chassis Type: 4F (4L0)
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 1E 36 37 42 46 47 4F
52 53 55 56 61 62 65 67 6C 6D 72 76 77
VIN: WAUKH74F08N026487 Mileage: 264250km-164197miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: Malfunction 0010
07-Control Head -- Status: Cannot be reached 1100
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: Cannot be reached 1100
0F-Digital Radio -- Status: Cannot be reached 1100
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
1E-Media Player 2 -- Status: Cannot be reached 1100
36-Seat Mem. Drvr -- Status: Malfunction 0010
37-Navigation -- Status: Cannot be reached 1100
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: Cannot be reached 1100
4F-Centr. Electr. II -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: Malfunction 0010
56-Radio -- Status: Cannot be reached 1100
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: Malfunction 0010
67-Voice Control -- Status: Cannot be reached 1100
6C-Back-up Cam. -- Status: Malfunction 0010
6D-Trunk Elect. -- Status: Malfunction 0010
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: Malfunction 0010
77-Telephone -- Status: Cannot be reached 1100
Address 01: Engine (AUK) Labels:. 06E-910-559-BKH.clb
Part No SW: 4F2 910 559 H HW: 4F1 907 559 E
Component: 3.2l V6 FSI 0040
Revision: --H21--- Serial number:
Coding: 010D0109190F0120
Shop #: WSC 02320 444 11631
VCID: 313F1427BD2728DF75F-8064
7 Faults Found:
005495 - Right Engine Mount Solenoid Valve (N145)
P1577 - 009 - Open Circuit
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 102
Reset counter: 40
Mileage: 262960 km
Time Indication: 0
Date: 2019.03.24
Time: 20:57:51
Freeze Frame:
RPM: 2048 /min
Mass Air / Rev.: 348.8 mg/str
Temperature: 52.5°C
Part Throttle
Load: 61.2 %
Speed: 25.0 km/h
005715 - Please check DTC Memory of ABS Controller
P1653 - 008 - - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 17
Reset counter: 10
Mileage: 263182 km
Time Indication: 0
Date: 2019.05.03
Time: 01:38:34
Freeze Frame:
RPM: 1920 /min
Mass Air / Rev.: 119.9 mg/str
Temperature: 39.0°C
Idle
Load: 18.8 %
Speed: 0.0 km/h
001110 - EVAP System
P0456 - 006 - Very Small Leak Detected - Intermittent
Freeze Frame:
Fault Status: 00000001
Fault Priority: 5
Fault Frequency: 1
Reset counter: 3
Mileage: 263414 km
Time Indication: 0
Date: 2007.03.04
Time: 16:06:35
Freeze Frame:
Lambda: -3.0 %
Temperature: 31.5°C
Temperature: 48.0°C
Speed: 0.0 km/h
Time: 102.4 s
Temperature: 520.0°C
009523 - Ignition Switch; Run/Start Position Circuit
P2533 - 006 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 6
Mileage: 263414 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Mass Air / Rev.: 0.0 mg/str
Temperature: 24.0°C
Engine Off
Voltage: 10.71 V
Speed: 0.0 km/h
005668 - MIL Request Signal Active (Check TCM for errors too!)
P1624 - 008 - - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 8
Mileage: 263414 km
Time Indication: 0
Date: 2007.03.07
Time: 22:33:05
Freeze Frame:
RPM: 1344 /min
Mass Air / Rev.: 354.3 mg/str
Temperature: 81.0°C
Part Throttle
Load: 58.0 %
Speed: 1.0 km/h
004440 - Manifold Pressure Sensor (G71)
P1158 - 007 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 7
Mileage: 263414 km
Time Indication: 0
Date: 2007.03.07
Time: 22:35:08
Freeze Frame:
RPM: 736 /min
Mass Air / Rev.: 179.9 mg/str
Temperature: 54.0°C
Idle
Voltage: 13.26 V
Speed: 0.0 km/h
000104 - MAP/MAF <-> Throttle Position Correlation
P0068 - 007 - - Intermittent
Freeze Frame:
Fault Status: 00000010
Fault Priority: 5
Fault Frequency: 1
Reset counter: 7
Mileage: 263414 km
Time Indication: 0
Date: 2007.03.07
Time: 22:35:08
Freeze Frame:
RPM: 736 /min
Temperature: 54.0°C
Idle
Voltage: 13.16 V
Bin. Bits: 00000010
Readiness: 0000 0000
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 4F5 910 156 HW: 09L 927 156 C
Component: AG6 09L 3.2 FSI USA 0010
Revision: --H03--- Serial number: 4345884
Coding: 0000002
Shop #: WSC 02325 758 00200
VCID: 6597B077B96FB47F597-8030
1 Fault Found:
006246 - Powertrain Data Bus
P1866 - 000 - Missing Messages - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 263414 km
Time Indication: 0
Address 03: ABS Brakes Labels: 4F0-910-517.clb
Part No SW: 4F0 910 517 AD HW: 4F0 614 517 AA
Component: ESP8 quattro H01 0070
Revision: 00000000 Serial number: 00000000000000
Coding: 0020895
VCID: 6695B77B4469BF6750D-8032
1 Fault Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - - - Intermittent
Freeze Frame:
Fault Priority: 3
Fault Frequency: 21
Reset counter: 159
Mileage: 263182 km
Time Indication: 0
Date: 2019.05.03
Time: 01:38:34
Freeze Frame:
Hex Value: 0x00C0
Hex Value: 0x4282
Hex Value: 0x0024
Hex Value: 0x0196
Hex Value: 0x00FF
Address 05: Acc/Start Auth. Labels:. 4F0-910-852.clb
Part No SW: 4F0 910 852 A HW: 4F0 905 852 C
Component: FBSAUDIC6 ELVSG H01 0040
Revision: 09010701 Serial number: 10601600829016
Coding: 0000135
Shop #: WSC 02323 758 00200
VCID: 2411ED73F2D58D778E9-8070
Subsystem 1 - Part No: 4F0 910 131 L
Component: FBSAUDIC6 EZS H45 0080
Subsystem 2 - Part No: 4F0 910 335
Component: FBSAUDIC6 KSG H27 0080
Subsystem 3 - Part No: 4F0 910 220 G
Component: FBSAUDIC6 IDG H01 0060
4 Faults Found:
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 10
Reset counter: 156
Mileage: 263182 km
Time Indication: 0
Date: 2019.05.02
Time: 23:41:31
00446 - Function Limitation due to Under-Voltage
Freeze Frame:
Fault Priority: 2
Fault Frequency: 100
Reset counter: 159
Mileage: 263182 km
Time Indication: 0
Date: 2019.05.02
Time: 23:40:16
02639 - Antenna Reader for Keyless Access Authorization
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Priority: 3
Fault Frequency: 21
Reset counter: 153
Mileage: 263414 km
Time Indication: 0
Date: 2000.01.01
Time: 12:00:00
02072 - Control Module for Energy Management (J644)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 153
Time Indication: 0
Address 07: Control Head
Cannot be reached
Address 08: Auto HVAC Labels: 4F0-910-043.clb
Part No SW: 4F0 910 043 A HW: 4F1 820 043 AG
Component: KLIMABETAETIGUNGH30 0020
Revision: 00000053 Serial number: 00000030263617
Coding: 0524582
VCID: 1C61D593CAA5B5B7369-8048
1 Fault Found:
00657 - Positioning Motor for Central Vents (V102)
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00100011
Fault Priority: 3
Fault Frequency: 7
Reset counter: 185
Mileage: 264082 km
Time Indication: 0
Date: 2007.03.09
Time: 13:44:41
Freeze Frame:
Voltage: 12.80 V
Temperature: 24.0°C
(no units): 83.0
(no units): 34.0
Temperature: 28.0°C
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 J HW: 4F0 907 279 A
Component: ILM Fahrer H18 0250
Revision: 00000000 Serial number: 4F0907279
Coding: 0113123
Shop #: WSC 02335 758 00200
VCID: 30391123B62D21D77A1-8064
Subsystem 1 - Part No: 4F1 910 113 C Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H05 0210
Coding: 00064784
Shop #: WSC 02335
Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH13 0090
Coding: 00146221
Shop #: WSC 02335
No fault code found.
Address 0E: Media Player 1
Cannot be reached
Address 0F: Digital Radio
Cannot be reached
Address 15: Airbags Labels: 4F0-910-655-8R.clb
Part No SW: 4F0 910 655 F HW: 4F0 959 655 A
Component: 6N AIRBAG AUDI8RH30 0300
Revision: 15H30000 Serial number: 00359D0G4KK4
Coding: 0013902
VCID: 2A0D034B90F15B07B45-807E
Subsystem 1 - Part No: 4F0 910 339 B
Component: BF-Gewichtsens. H03 0060
Subsystem 2 - Serial number: 6332CSME15745B5FE
Subsystem 3 - Serial number: 6342CSME19371663+
Subsystem 4 - Serial number: 6352QSME314C4963J
Subsystem 5 - Serial number: 6362QSME330627739
Subsystem 6 - Serial number: 63734SME31494819/
Subsystem 7 - Serial number: 63834SME2D212347-
1 Fault Found:
02095 - Component Protection Active
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 A HW: 4F0 953 549 D
Component: J0527 0410
Revision: 00H02000 Serial number: 90054071860221
Coding: 0012042
VCID: 270BFA7F83E3666FABB-8072
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H02 0030
2 Faults Found:
Freeze Frame:
Fault Status: 01100010
Fault Priority: 6
Fault Frequency: 27
Reset counter: 255
Mileage: 263182 km
Time Indication: 0
Date: 2019.05.02
Time: 23:48:53
Freeze Frame:
Fault Priority: 4
Fault Frequency: 3
Reset counter: 159
Mileage: 263182 km
Time Indication: 0
Date: 2019.05.02
Time: 23:50:23
Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
Part No SW: 4F0 910 930 C HW: 4F0 920 983
Component: KOMBIINSTR. M73 H21 0220
Revision: 00600000 Serial number: 6IK54GX67
Coding: 3153288
Shop #: WSC 44189 002 1048576
VCID: 2313EE6FF7DB8A4FF73-8076
Address 19: CAN Gateway Labels:. 4L0-910-468.clb
Part No SW: 4L0 910 468 HW: 4L0 907 468
Component: J533__Gateway H06 0040
Revision: 00H06000 Serial number: 0900B07529808E
Coding: F5D5FE77707A06
Shop #: WSC 22172 444 90278
VCID: 6C81C5535A858537069-8038
2 Faults Found:
00384 - Optical Databus
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 9
Reset counter: 154
Mileage: 262959 km
Time Indication: 0
Date: 2019.03.24
Time: 20:54:31
01301 - Control Module for Voice Recognition (J507)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 104
Mileage: 263182 km
Time Indication: 0
Date: 2019.05.03
Time: 05:47:05
Address 1E: Media Player 2
Cannot be reached
Address 36: Seat Mem. Drvr Labels: None
Part No SW: 4F0 910 760 HW: 4F0 959 760
Component: Sitzmemory FS H04 0050
Revision: 00000000 Serial number: 00000000896400
Coding: 0082954
Shop #: WSC 02334 758 00200
VCID: 619FA467AD47D85FA5F-8034
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 159
Mileage: 0 km
Time Indication: 0
Date: 2007.01.01
Time: 00:00:00
Address 37: Navigation
Cannot be reached
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 793 E
Component: TSG FA H12 0210
Revision: 00-00000
Coding: 0052971
Shop #: WSC 02327 758 00200
VCID: 2C0105539A054537469-8078
Address 46: Central Conv. Labels:. 4F0-910-289.lbl
Part No SW: 4F0 910 289 K HW: 4F0 907 289 K
Component: Komfortgeraet H25 0200
Revision: 02000025 Serial number: 01053861030000
Coding: 7764509
VCID: 323D1B2BB82113C70C5-8066
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Address 47: Sound System
Cannot be reached
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 C
Component: ILM Beifahrer H12 0100
Revision: Serial number: 00000000039835
Coding: 0002014
VCID: 5EE59F9B9C39E7A798D-800A
1 Fault Found:
Freeze Frame:
Fault Status: 00110010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 155
Mileage: 262136 km
Time Indication: 0
Date: 2007.03.07
Time: 19:51:00
Freeze Frame:
Voltage: 5.900 V
Not Recogn.
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 792 E
Component: TSG BF H12 0210
Revision: 00-00000
Coding: 0052971
Address 53: Parking Brake Labels: 4F0-910-801.clb
Part No SW: 4F0 910 801 C HW: 4F0 907 801 A
Component: EPB CDEC0080 H04 0080
Revision: --H04---
Coding: 0005022
Shop #: WSC 00000 758 00200
VCID: 2019E163E6CD9157EA1-8074
Address 55: Headlight Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Revision: 00000001 Serial number:
Coding: 0000016
VCID: 290FFC4795F7501FBDF-807C
Subsystem 1 - Part No: 4F0 941 329 D
Component: AFS-Modul links H01 0010
Subsystem 2 - Part No: 4F0 941 329 D
Component: AFS-Modul rechtsH01 0010
1 Fault Found:
02626 - Dynamic Cornering Light Motor; Right (V319)
010 - Open or Short to Plus - MIL ON
Freeze Frame:
Fault Status: 11101010
Fault Priority: 2
Fault Frequency: 162
Reset counter: 40
Mileage: 262952 km
Time Indication: 0
Date: 2019.03.24
Time: 19:06:11
Address 56: Radio
Cannot be reached
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: J0644 BEM H12 0590
Revision: 00000000 Serial number: 00000000107232
Shop #: WSC 22569 444 53330
Subsystem 1 - Part No: 4F0 915 105 E
Component: von VA0 1234567890
Coding: 344630393135313035452056413031323334353637383930
Shop #: WSC 12345 384 00290
5 Faults Found:
02272 - Quiescent Current Stage 1
Freeze Frame:
Fault Priority: 7
Fault Frequency: 9
Reset counter: 255
Mileage: 263544 km
Time Indication: 0
Date: 2007.03.04
Time: 12:51:11
02273 - Quiescent Current Stage 2
Freeze Frame:
Fault Priority: 7
Fault Frequency: 8
Reset counter: 255
Mileage: 263544 km
Time Indication: 0
Date: 2007.03.04
Time: 12:54:44
02276 - Quiescent Current Stage 5
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 263544 km
Time Indication: 0
Date: 2007.03.04
Time: 20:53:16
02274 - Quiescent Current Stage 3
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 263544 km
Time Indication: 0
Date: 2007.03.04
Time: 20:53:34
02256 - Quiescent Current
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 7
Fault Frequency: 4
Reset counter: 190
Mileage: 263722 km
Time Indication: 0
Date: 2007.03.06
Time: 11:54:54
Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 795 E
Component: TSG HL H21 0210
Coding: 0052778
VCID: 2E050F5BAC19372768D-807A
Address 65: Tire Pressure Labels: 4F0-910-273-BA.lbl
Part No SW: 4F0 910 273 B HW: 4F0 907 273 A
Component: Reifendruck 3 H05 0100
Revision: 00050100 Serial number: 00000700049343
Coding: 0062221
VCID: 221DEB6BE8C18347FC5-8076
2 Faults Found:
002 - Lower Limit Exceeded - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 156
Mileage: 263414 km
Time Indication: 0
Date: 2007.03.07
Time: 22:22:47
Freeze Frame:
(no units): 0.0
Voltage: 6.50 V
(no units): 42.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
01521 - Sensor for Tire Pressure
004 - No Signal/Communication - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100100
Fault Priority: 3
Fault Frequency: 21
Reset counter: 190
Mileage: 263025 km
Time Indication: 0
Date: 2019.03.31
Time: 03:10:51
Freeze Frame:
(no units): 108.0
Voltage: 13.10 V
(no units): 61.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Address 67: Voice Control
Cannot be reached
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 4F0 910 441 A HW: 4L0 907 441 A
Component: J772__Rearview 0050
Revision: --H12--- Serial number: 525PA8-J76303A
Coding: 1000305
VCID: 1E65DF9BDCB9A7A7D8D-804A
2 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 99
Reset counter: 159
Mileage: 263182 km
Time Indication: 0
Date: 2019.05.02
Time: 23:42:29
Freeze Frame:
Term 15 Off
Reverse OFF
Count: 3
Freeze Frame:
Fault Priority: 3
Fault Frequency: 4
Reset counter: 159
Time Indication: 0
Freeze Frame:
Term 15 Off
Reverse OFF
Count: 3
Address 6D: Trunk Elect. Labels: Redir Fail!
Part No SW: 4F9 910 591 HW: 4F9 827 851 F
Component: ValeoHeckdeckel H24 0280
Revision: --H24001 Serial number: E5030000B
Shop #: WSC 98765 666 38354
Subsystem 1 - Part No: 4F9 910 592
Subsystem 2 - Serial number: E5030100B
Subsystem 3 - Serial number: RD07.07.07--H24001001B0147ÿ
Subsystem 4 - Serial number: 1B0147ÿ
1 Fault Found:
01336 - Company Data Bus for Comfort System
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 3
Fault Frequency: 1
Reset counter: 153
Mileage: 0 km
Time Indication: 0
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 794 E
Component: TSG HR H21 0210
Coding: 0052778
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4F0 910 283 F HW: 4F0 919 283 F
Component: Parkhilfe 4-Kan H09 0060
Revision: 00H09000 Serial number: 06230719001855
Coding: 0021216
Shop #: WSC 131071 1023 2097151
2 Faults Found:
01547 - Sensor for Parking Aid; Rear Mid-Right (G205)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 88
Mileage: 262959 km
Time Indication: 0
Date: 2019.03.24
Time: 20:57:12
00456 - Control Module for Access and Start Control (J518)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 3
Reset counter: 40
Mileage: 0 km
Time Indication: 0
Address 77: Telephone
Cannot be reached
End----(Elapsed Time: 02:01, VBatt start/end: 11.7V/11.7V. VIgn 11.8V)-----
www.Ross-Tech.com
7 Faults Found:
Freeze Frame:
Fault Priority: 2
Reset counter: 40
Mileage: 262960 km
Time Indication: 0
Date: 2019.03.24
Time: 20:57:51
Freeze Frame:
RPM: 2048 /min
Temperature: 52.5°C
Part Throttle
Load: 61.2 %
Speed: 25.0 km/h
Freeze Frame:
Fault Priority: 2
Fault Frequency: 17
Reset counter: 10
Mileage: 263182 km
Time Indication: 0
Date: 2019.05.03
Time: 01:38:34
Freeze Frame:
RPM: 1920 /min
Temperature: 39.0°C
Idle
Load: 18.8 %
Speed: 0.0 km/h
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 3
Mileage: 263414 km
Time Indication: 0
Date: 2007.03.04
Time: 16:06:35
Freeze Frame:
Lambda: -3.0 %
Temperature: 31.5°C
Temperature: 48.0°C
Speed: 0.0 km/h
Time: 102.4 s
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 6
Mileage: 263414 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Temperature: 24.0°C
Engine Off
Voltage: 10.71 V
Speed: 0.0 km/h
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 8
Mileage: 263414 km
Time Indication: 0
Date: 2007.03.07
Time: 22:33:05
Freeze Frame:
RPM: 1344 /min
Temperature: 81.0°C
Part Throttle
Load: 58.0 %
Speed: 1.0 km/h
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 7
Mileage: 263414 km
Time Indication: 0
Date: 2007.03.07
Time: 22:35:08
Freeze Frame:
RPM: 736 /min
Temperature: 54.0°C
Idle
Voltage: 13.26 V
Speed: 0.0 km/h
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 7
Mileage: 263414 km
Time Indication: 0
Date: 2007.03.07
Time: 22:35:08
Freeze Frame:
RPM: 736 /min
Temperature: 54.0°C
Idle
Voltage: 13.16 V
Bin. Bits: 00000010
Coding: 0000002
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 263414 km
Time Indication: 0
Coding: 0020895
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 21
Reset counter: 159
Mileage: 263182 km
Time Indication: 0
Date: 2019.05.03
Time: 01:38:34
Freeze Frame:
Hex Value: 0x00C0
Hex Value: 0x4282
Hex Value: 0x0024
Hex Value: 0x0196
Hex Value: 0x00FF
Coding: 0000135
4 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 10
Reset counter: 156
Mileage: 263182 km
Time Indication: 0
Date: 2019.05.02
Time: 23:41:31
Freeze Frame:
Fault Priority: 2
Reset counter: 159
Mileage: 263182 km
Time Indication: 0
Date: 2019.05.02
Time: 23:40:16
Freeze Frame:
Fault Priority: 3
Fault Frequency: 21
Reset counter: 153
Mileage: 263414 km
Time Indication: 0
Date: 2000.01.01
Time: 12:00:00
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 153
Time Indication: 0
Cannot be reached
Coding: 0524582
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 7
Reset counter: 185
Mileage: 264082 km
Time Indication: 0
Date: 2007.03.09
Time: 13:44:41
Freeze Frame:
Voltage: 12.80 V
Temperature: 24.0°C
(no units): 83.0
(no units): 34.0
Temperature: 28.0°C
Coding: 0113123
Coding: 00064784
Shop #: WSC 02335
Coding: 00146221
Shop #: WSC 02335
Cannot be reached
Cannot be reached
Coding: 0013902
1 Fault Found:
Coding: 0012042
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 27
Reset counter: 255
Mileage: 263182 km
Time Indication: 0
Date: 2019.05.02
Time: 23:48:53
Freeze Frame:
Fault Priority: 4
Fault Frequency: 3
Reset counter: 159
Mileage: 263182 km
Time Indication: 0
Date: 2019.05.02
Time: 23:50:23
Coding: 3153288
2 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 9
Reset counter: 154
Mileage: 262959 km
Time Indication: 0
Date: 2019.03.24
Time: 20:54:31
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 104
Mileage: 263182 km
Time Indication: 0
Date: 2019.05.03
Time: 05:47:05
Cannot be reached
Coding: 0082954
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 159
Mileage: 0 km
Time Indication: 0
Date: 2007.01.01
Time: 00:00:00
Cannot be reached
Revision: 00-00000
Coding: 0052971
Coding: 7764509
Cannot be reached
Coding: 0002014
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 155
Mileage: 262136 km
Time Indication: 0
Date: 2007.03.07
Time: 19:51:00
Freeze Frame:
Voltage: 5.900 V
Not Recogn.
Revision: 00-00000
Coding: 0052971
Revision: --H04---
Coding: 0005022
Coding: 0000016
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Reset counter: 40
Mileage: 262952 km
Time Indication: 0
Date: 2019.03.24
Time: 19:06:11
Address 56: Radio
Cannot be reached
5 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 9
Reset counter: 255
Mileage: 263544 km
Time Indication: 0
Date: 2007.03.04
Time: 12:51:11
Freeze Frame:
Fault Priority: 7
Fault Frequency: 8
Reset counter: 255
Mileage: 263544 km
Time Indication: 0
Date: 2007.03.04
Time: 12:54:44
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 263544 km
Time Indication: 0
Date: 2007.03.04
Time: 20:53:16
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 263544 km
Time Indication: 0
Date: 2007.03.04
Time: 20:53:34
Freeze Frame:
Fault Priority: 7
Fault Frequency: 4
Reset counter: 190
Mileage: 263722 km
Time Indication: 0
Date: 2007.03.06
Time: 11:54:54
Coding: 0052778
Coding: 0062221
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 156
Mileage: 263414 km
Time Indication: 0
Date: 2007.03.07
Time: 22:22:47
Freeze Frame:
(no units): 0.0
Voltage: 6.50 V
(no units): 42.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Freeze Frame:
Fault Priority: 3
Fault Frequency: 21
Reset counter: 190
Mileage: 263025 km
Time Indication: 0
Date: 2019.03.31
Time: 03:10:51
Freeze Frame:
(no units): 108.0
Voltage: 13.10 V
(no units): 61.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Cannot be reached
Coding: 1000305
2 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 99
Reset counter: 159
Mileage: 263182 km
Time Indication: 0
Date: 2019.05.02
Time: 23:42:29
Freeze Frame:
Term 15 Off
Reverse OFF
Count: 3
Freeze Frame:
Fault Priority: 3
Fault Frequency: 4
Reset counter: 159
Time Indication: 0
Freeze Frame:
Term 15 Off
Reverse OFF
Count: 3
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 153
Mileage: 0 km
Time Indication: 0
Coding: 0052778
Coding: 0021216
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 88
Mileage: 262959 km
Time Indication: 0
Date: 2019.03.24
Time: 20:57:12
Freeze Frame:
Fault Priority: 4
Fault Frequency: 3
Reset counter: 40
Mileage: 0 km
Time Indication: 0
Cannot be reached
We had the same problem a couple years ago on our Avant. The dealer ultimately had to do some minor re-coding and remove Component Protection. (I had the amp repaired in NJ and also fitted a new receiver.)
I have Sirius although I’m not subscribed to it. Bluetooth has been working fine but like everything else without the mmi it’s down. New battery that’s fully charged and coded in the system.
If Bluetooth was working fine, it could be your Sirius module going bad and causing your MMI to malfunction. The Sirius module is located in the trunk, on the driver's side. Open the side compartment and it should be in there, placed vertically, facing the tail light. Check out its temperature. Is it cold/warm/hot?
+pressure
06-22-2005 09:21 AM
cat30
10-17-2004 03:12 PM
UK_Greg
03-18-2003 07:47 AM
