If a wire input to the sub came loose - would what cause the amp to go into protection mode?
I was trying to diagnose my problem today (see lower post) when i found one of the wires going into the terminal cup was just barely in there and about to fall out. If this wire were to come out would that cause the amp to go into protection mode?
thanks,
matt
thanks,
matt
Re: If a wire input to the sub came loose - would what cause the amp to go into protection mode?
Yes. Most amps work in the range between 2 - 8 ohms, a connection that came off would equal 0 ohms.
a connection that came off would be INFINITY ohms wouldn't it? (more)
if the wire pulled out and isn't touching anything you're ok. (you'll get no sound of course)
if the wire came off and is touching something you'll have problems.
wildaman85
08-14-2006 05:10 PM
Ok still have an amp problem...If i disconnect the front fuse the amp will come back on for a few ..
starting ...
10-01-2005 04:14 PM
Ground_Pounder_65
05-02-2005 04:28 AM
Kirath ¾-B0§t0n
07-10-2001 12:19 PM
