How to get more power out of your air tools
Yesterday, I installed a mount for a snow plow on the front of my F-350. It's a pretty small personal snow plow made by SnowBear, but it's the right size for my driveway. (I used to have this plow on the old F-150).
The plow mount uses special metal lock nut that takes an incredible of mount of torque to turn. I have the most powerful 1/2 impact wrench that Ingersol Rand makes and at about 115 PSI which is the max of the compressor, it was not enough to tighten the nut. (The bolt/nut at issue took a 24mm socket)
I switched from the 3/8" 75' hose on my hose reel to a 1/2" 50' long hose. I was shocked that the impact wrench turned the nut with minimal issues. Looks like 3/8" hose has significant restrictions as compared to half inch. I'd estimate that wrench had at least 30% more power.
<IMG SRC="http://pictureposter.audiworld.com/28004/dsc_0078.jpg" BORDER="0">
Here's a picture of the impact wrench connected to the 1/2" hose.
<IMG SRC="http://pictureposter.audiworld.com/28004/dsc_0080.jpg" BORDER="0">
Here's a picture of the plow mount on the truck. You're just looking at what is exposed. There is a serious bracket on each side bolted to the frame.
Audi Content - When changing a pressed-in wheel bearing on your Audi, you really need as much oomph as possible out of your impact wrench. This larger hose will do it.
interesting air compressor mod
Never thought that the hose diameter or length would make a difference. I guess it makes sense.
Funny, Rob and I were using my air tools to get the two bolts off on the H-Sport rear sway on my car. I wanted to adjust it to the tightest setting. The 90PSI on the compressor wasn't enough for the tool. I had to turn the output up to 110PSI for the tool to be able to run to loosen the bolts.
vwleadfoot
Audi Original "S" Cars
12-24-2015 06:07 AM
saifxnyc
9
11-30-2015 12:32 PM
ECS Tuning-Audi
A4 (B7 Platform) Discussion
09-01-2015 09:16 AM
ECS Tuning-Audi
09-01-2015 08:27 AM
