Help with rear brakes on Audi 100
Hello,
I'm planning to replace the rear brake pads on my Audi 100 '89 this comming weekend. The car has 120K+ miles and i still have the original pads with about 2mm left on them. I have new pads now and it's time for replacement. The rotors look very good.
I tried to do the procedure myself not long ago and i had the following problem:
I couldn't push back the piston on the caliper. It went in only 2-3 mm and then it become very difficult (impossible!) to move it further in. I didn't have the best tool for the job so i blamed the problem on it. However, week later i replaced the front pads using the same tool and the pistons went back with not much trouble. Easy!
Why are the rear pistons stuck??? I wonder, Can this be due to the parking brake? Should i do something to it before i try to push back the pistons? Any hints/tricks? The calipers are Girling type and they don't look damaged or rusty or wet. Do i need new calipers if the piston is "stuck"? Or i need a better tool to push with?
Help me people!
Thanks!
DanA100
Help me people!
Thanks!
DanA100
Don't really know but just sniffing around it looks like ...
you may need to screw the rear pistons back in.
Look here http://www.20v.org/brakmain.htm
I looked in my Bentley Manual for 92 -97 100 and A6, it shows the special tool mentioned on the 20valve web site.
Ahh, the pleasures of a German car.
Re:it's because of the hand brake
The hand brake opperates on on some kind of a screw mecanisim. I had the same problem, even broke off a C-clamp.
Depending on weather or not you pistons are orig. or rebuilt you should be able to you an allan or hex key- as for what size I don't remember.
A pair of needle nose pliers will work but a key is faster and will keep the piston in good shape.
It's just as well to screw the piston in almost all the way instead of a bit and try a bit and try.
Also some recomend losening the resivoir cap to ease of some of the preasure....
Good luck
mike90q
Good luck
mike90q
The piston surface is flat ..... can't screw back
I know what you mean, the manual shows the piston on Garling Calipers to have Hex. "opening" on its surface so it can be rotated with tool and pushed(screwed) back.
Mine does NOT have this!!! It is flat, solid metal with two side "channels"(are these channels made for a different tool) Any hints to solve this?
So, should i actually do something with the hand brake adjustment BEFORE i start pushing the pistons back???
Thank you.
DanA100
Thank you.
DanA100
This is what I used to do it....
...I bought this at my local NAPA store for a few bucks. Took a Dremel tool to it and ground off two of the prongs. The result is....
<img src="http://pictureposter.audiworld.com/1889/braketool.jpg">
....it works perfect. Stick it on the end of a ratchet and you'll get that piston pushed back in no time!!!
Good Luck!!!
Andrew
90 80q
91 90
95 90q
Good Luck!!!
Andrew
90 80q
91 90
95 90q
Re: Stick the tips of the needle nose in those channels, and turn....
It looks like needle nose it is.
There is a tool for leather I think that if I remember correctly is shaped just right for what you are describing.
However, maybe you should go to an automotive place, like pep boy's or something, and see if they got a loan-a-tool program. I get my speciality tool's, like tie rod tool and spring compreser etc., at canadain tire. Try something like that if you would rather instead of the plier trick.
Sorry to put down the pliers didn't have the details....
mike 90q
mike 90q
Re: The piston surface is flat ..... can't screw back
The piston does screw back. Go to any parts store and ask them for a brake piston tool, it'll be a cube about two inches across with different shaped stubs on each side, and a hole in the middle for a 3/8" ratchet. This should do the trick.
Andrewbens
07-14-2009 05:57 AM
itdoesitallroad
Audi allroad
01-16-2006 08:04 AM
audiseefu
10-03-2004 08:05 AM
computrtutr
9
04-17-2003 09:21 AM
