oil light
Old Aug 3, 1999 | 07:35 AM
Patricia Wong
Guest
Posts: n/a
Default oil light
This is for those of you who do your own oil change. Does anyone know how to reset the "OIL" light?
Old Aug 3, 1999 | 09:35 AM
Andy Hedin
Guest
Posts: n/a
Default Resetting "OIL" light...
I change my oil on my '97 A4 and unfortunately, the service indicators (OIL, IN1, IN2) can not be reset on the 97's unless you have a VAG tool. I'm pretty sure this was also the case with the '96 A4 and the early '98 A4. At some point (98.5??) Audi changed things and there is a procedure (supposedly documented in the owner's manual) which will allow you to reset that service indicator.<p>Hope this helps,<p>Andy Hedin
Old Aug 3, 1999 | 09:46 AM
Todd W
Guest
Posts: n/a
Default Mine goes out when I top off the oil
The oil light on most Audis tells you that you are low on oil. Add a quart.
HedonismBot
Mar 24, 2005 07:48 PM
czechchamp
Nov 5, 2003 09:23 AM
///Mracer
Sep 24, 2003 11:51 AM
raduja
Jan 3, 2003 05:17 AM
JD
Apr 13, 1999 08:55 AM
