Need help with ignition switch replacement in Brighton
Is there anyone that can assist me with an ignition switch replacement on a 92 100CSq?
It should be the same procedure for 100/200/S4/S6 as they all have similar instrument clusters. The problem is that I can't get the instrument cluster out to access the switch. I pulled all the necessary screws but it seems to be binding on the bottom. I've read all the FAQ's and I think there should be enough slack in the harnesses to see the back of the IC.
thanks.
thanks.
I'll be up there this weekend and have done this a few times
shoot me an email to the address linked in my username and I'll give you a hand. I should be up there sat afternoon, and then will be out working on my S6 at my parents' place in the suburbs on sunday.
Re: I'll be up there this weekend and have done this a few times
Thanks,
Here's an update.
Cluster is out. The FAQ never mentioned anything about a lip below the cluster. That's where it was binding. I had to lift the cluster slightly and muscle it out.
Switch is also out. Now it's time to get the new one in.
To be continued.......
Here's an update.
Re: nice. the new switch requires a little muscling into place as well, the HVAC ducts get in the wa
It's done. Thank you for offering to come down.
I tried every possible angle to get the switch out and finally it came out. Getting it back in there wasn't that bad. i just had to remember how the harness folded back in there.
Quetzal
Wheels & Tires Discussion
09-23-2015 07:50 PM
ZPA117
A4 (B8 Platform) Discussion
09-08-2015 11:55 AM
stormchaser1967
09-02-2015 09:26 AM
stormchaser1967
09-02-2015 09:02 AM
