So it turns out my car is still under my CPO warranty until June 07/100K miles.
I'm taking her into Jack Daniels Thurs for the following:
-Need new gauge cluster (pixel line out)
-oil buildup on hoses (brought it into Quattrohaus - can't figure out the culprit)
-rear license plate light burnt out (replaced bulb, but the bracket needs replacing...still doesn't work)
-hairline cracks on the side of the coolant reservoir tank
-rear differential seal (very slight oil buildup)
-tear on small rubber boot of the right lower control arm
-Airbag light went on once last wk, never came back (not sure what was going on here)
Jack Daniels has never given me a problem with warranting my modded A4. What do you guys think will be covered and won't?
i dunno about their svc writers....
but technically i believe the cluster, the diff seal might be covered and the control arm should be covered. and they'll vag the ABS system and maybe try to clean the sensor on the corner that tripped the light.
*edited* whoops I meant AIRBAG light. lol. I have more repairs I just added...
-cigarette lighter doesn't work (not the fuse since my car cell charger works)
-stock bent audi jack (they've replaced this once, it bent again on me)
-missing screws on belly pan =) (which they've replace for me on a # of occasions)
Am I pushing my luck at this point? lol.
ill give you the toolkit from an allroad its got the jack and tools in a hard case....
i had it for my old car but the new one has all that sh*t stowed away nicely, and the stuffs clogging up my apt.
carl viking
36
04-27-2020 01:17 PM
ECS Tuning-Audi
S4 (B8 Platform) Discussion
09-01-2015 11:57 AM
