VAG codes from auto-scan... Anyone care to put in their 2 cents?
Not sure what some of these mean... Anything significant?
VCDS Version: Release 805.1
Data version: 20081017
Monday,10,November,2008,20:10:54:24102
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
VIN: Mileage: 64820km/40277miles
Address 01: Engine Labels: Redir Fail!
Part No SW: 8E0 910 560 A HW: 8E0 907 560
Component: 4.2L V8/5V G 0020
Coding: 0007711
Shop #: WSC 09401 444 58697
1 Fault Found:
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 002 - Lower Limit Exceeded - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517 Q
Component: ABS/ESP allrad 3033
Coding: 04595
Shop #: WSC 06435
No fault code found.
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 AD
Component: A4 Klimaautomat 1219
Coding: 00000
Shop #: WSC 63351
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
Part No: 8E0 907 279 F
Component: int. Lastmodul RDW 0517
Coding: 01011
Shop #: WSC 63351
Address 0F: Digital Radio Labels: 8E0-035-593-XM.lbl
Part No SW: 8E0 035 593 A HW:
Component: SDAR XM
Revision: Serial number: AUZ4Z7C3003748
Shop #: WSC 00000 000 00000
1 Fault Found:
02635 - Tuner Not Enabled/Activated
000 - -
Address 15: Airbags Labels: 8E0-959-655-84.lbl
Part No: 8E0 959 655 C
Component: Airbag 8.4EP 3001
Coding: 0010707
Shop #: WSC 63351 000 00000
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 N
Component: Lenksáulenmodul 0611
Coding: 01041
Shop #: WSC 63351
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8E0 920 981 GX
Component: KOMBI+WEGFAHRS. RB8 D42
Coding: 03201
Shop #: WSC 06532
WAUPL58E94A068135 AUZ6Z0C0196184
1 Fault Found:
01304 - Radio
49-10 - No Communications - Intermittent
Address 36: Seat Mem. Drvr Labels: 8E0-959-760.lbl
Part No: 8E0 959 760
Component: Sitzmemory R2 F 0305
Coding: 00002
Shop #: WSC 06435
Address 37: Navigation Labels: Redir Fail!
Part No: 4B0 919 887 E
Component: BNS 4.2 H05 BNO 0050
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 BB
Component: Komfortgerát T7B 1411
Coding: 11848
Shop #: WSC 06532
Part No: 8E1959801
Component: Tõrsteuer.FS BRM 0003
Part No: 8E1959802E
Component: Tõrsteuer.BF BRM 0003
Part No: 8E0959801A
Component: Tõrsteuer.HL BRM 0003
Part No: 8E0959802A
Component: Tõrsteuer.HR BRM 0003
1 Fault Found:
01572 - Alarm triggered by Door Contact Switch; Passenger Side
35-00 - -
Address 55: Xenon Range Labels: 4Z7-907-357.lbl
Part No: 4Z7 907 357
Component: dynamische LWR D09
Coding: 00060
Shop #: WSC 63351
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Part No SW: 8E0 035 192 Q HW: 8E0 035 192 Q
Component: RNS-E US H73 0260
Revision: 02S Serial number: AUZBZ7F1125880
Coding: 0301635
3 Faults Found:
00446 - Function Limitation due to Under-Voltage
Freeze Frame:
Fault Status: 00100010
Fault Priority: 7
Fault Frequency: 1
Reset counter: 137
Time Indication: 0
Date: 2003.08.01
Time: 00:00:30
Freeze Frame:
Voltage: 11.80 V
Mileage: 655350 km
Count: 65535
Clock: 255:255
00858 - Connection; Radio ZF Output to Antenna Amplifier
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 137
Time Indication: 0
Date: 2008.08.24
Time: 19:16:00
Freeze Frame:
Mileage: 655350 km
Count: 911
Clock: 16:25
00466 - Control Module for Steering Column Electronics (J527)
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 5
Fault Frequency: 1
Reset counter: 44
Time Indication: 0
Date: 2008.08.24
Time: 19:16:35
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8P0 862 335 R HW: 8P0 862 335 R
Component: FSE_255x BT H26 0350
Revision: 00000000 Serial number: 00000005050015
Coding: 0010777
End ---------------------------------------------------------------------
69 75 76 77
Coding: 0007711
1 Fault Found:
Coding: 04595
Shop #: WSC 06435
Coding: 00000
Shop #: WSC 63351
Coding: 01011
Shop #: WSC 63351
Component: SDAR XM
1 Fault Found:
000 - -
Coding: 0010707
Coding: 01041
Shop #: WSC 63351
Coding: 03201
Shop #: WSC 06532
1 Fault Found:
01304 - Radio
Coding: 00002
Shop #: WSC 06435
Coding: 11848
Shop #: WSC 06532
Part No: 8E1959801
Part No: 8E1959802E
Part No: 8E0959801A
Part No: 8E0959802A
1 Fault Found:
35-00 - -
Coding: 00060
Shop #: WSC 63351
Coding: 0301635
3 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 137
Time Indication: 0
Date: 2003.08.01
Time: 00:00:30
Freeze Frame:
Voltage: 11.80 V
Mileage: 655350 km
Count: 65535
Clock: 255:255
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 137
Time Indication: 0
Date: 2008.08.24
Time: 19:16:00
Freeze Frame:
Mileage: 655350 km
Count: 911
Clock: 16:25
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 44
Time Indication: 0
Date: 2008.08.24
Time: 19:16:35
Coding: 0010777
I took a stab at P1602...but check the link for the rest
P1602:
Possible Causes:
Cables on the Battery were removed
Battery weak (voltage)
Generator Disfunction
Possible Solutions:
Check Battery Cables
Check/Replace Battery
Check/Replace Generator
Special Notes:
If multiple Control Module have Power Supply Faults stored, it's most likely to be one common Problem like the ones shown above. Otherwise when only one or two Control Modules have such Codes stored you better start searching at the individual Power Supply of these Modules.<ul><li><a href="http://wiki.ross-tech.com/index.php/Category:Fault_Codes">http://wiki.ross-tech.com/index.php/Category:Fault_Codes</a</li></ul>
Possible Causes:
Possible Solutions:
Special Notes:
ValleyAviatorBlue
A6 (C7 Platform) Discussion
52
01-27-2016 09:10 PM
Audi Other 2013 Audi RS5 (low mileage) $61,000
buiyahkah
09-07-2015 09:29 AM
ajg617
09-06-2015 07:23 AM
