Can someone school me on B6 S4 offsets? Wheel people...
So what is the stock rim size/offset?
I'm looking at 18x8.5 with 35mm offset...where will this put the wheel?
What about an 18x8 wheel with a 45mm offset? Does that sink the wheel in closer? How about a 37mm offset?
I'd like to push the wheels out a bit, the seem tucked under the car now...especially in the rear. Advice?
18x8.0" ET45 is factory B6 Avus spec
To push the wheels out you want a numerically lower offset, 18x8.0" ET35 is likely the most common fitment but leaves a small bit of room to go further. 18x8.5" ET35 will be very flush in the back but a bit aggressive in the front, we typically do ET38 for an 8.5" wheel.
And this.
<ul><li><a href="http://www.tirerack.com/a.jsp?a=AR4&url=%2Fwheels%2Ftech%2Ftechpage.jsp%3F techid%3D101">http://www.tirerack.com/wheels/tech/techpage.jsp?techid=101</a></li></ul>
markbradford
06-03-2001 09:05 PM
Mark P
11-05-1999 10:16 AM
