lskolnick - good article!
thanks man, more installments to come to bring the car up to date. as you can see in my sig
the car is a bit further along than the article suggests. There is also even more to come if you check what's "on the bed".
Re: thanks man, more installments to come to bring the car up to date. as you can see in my sig
did i ever tell you that I could get you those infinity 6.5" coaxs for only $38.62
here's a couple of the products I have access to. I also can get JBL and Harmon Kardon
<img src="http://www.myharman.com/images/products/REF5010CS.jpg">
5-1/4" two-way component system with outboard crossover and I-mount tweeter mounting kit including Startfish OEM adapter.$69.52
Original Price: $209.95/Pair
<img src="http://www.myharman.com/images/products/REF311A.jpg">
REF311A
300 Watt Subwoofer Amplifier $105.94
Original Price: $299.95/Each
<img src="http://www.myharman.com/images/products/KAPPAPERFECT5_1.jpg">
KAPPA PERFECT 5.1
Deep-anodized-aluminum woofer cone ensures incredible detail and accuracy. This material holds its shape regardless of output level, unlike more commonly used materials, such as polypropylene. An incredible 1" deep-anodized-aluminum tweeter with rubber surround is used in the Perfect 5.1 to deliver incredble accuracy and detail. In addition, this edge-driven dome tweeter will handle plenty of power, making the 5.1 a great choice for the enthusiast looking for a system that will sound every bit as good at high output levels as at moderate ones. A precision outboard crossover using a Linquitz-Riley acoustic alignment is used to precisely divide frequencies between the mid-woofer and tweeter. The tweeter crossover frequency is set at 3.5kHz, facilitating exceptional mid-woofer to tweeter transition. This well-executed crossover also pro 5-1/4" Component System $154.50/Pair
MSRP U.S. $529.95 pair
<img src="http://www.myharman.com/images/products/KAPPA50_7CS.jpg">
KAPPA50.7CS
5-1/4" two-way component system with outboard crossover and I-mount tweeter mounting kit including Startfish OEM adapter.$108.15
Original Price: $329.95/Pair
<img src="http://www.myharman.com/images/products/REF7541A.jpg">
REF7541A
520 Watt 4-channel amplifier $127.46
Original Price: $374.95/Each
<img src="http://www.myharman.com/images/products/REF611A.jpg">
REF611A
600 Watt Class D Subwoofer Amplifier $148.69
Original Price: $424.95/Each
if you don't see what you're looking for, let me know. so you know, I'm not profiting off this, These are the prices I'm given. I just figure I'd hook you up.
REF311A
KAPPA PERFECT 5.1
KAPPA50.7CS
REF7541A
REF611A
any chance that I could access some of those products in about 3 weeks?
Looking for one, maybe two, sets of perfects... and an applicable amp... If this was a lskolnik offer only, thanks anyway. and maybe he'll be talking to you.
giuseppepat
09-02-2015 02:47 AM
