Performance and Tuning Discussion forum for various performance tuning techniques and questions
Emission code 0171
Old Jan 29, 2019 | 07:13 AM
Gills2019's Avatar
Default Emission code 0171
A4 Cabriolet 1.8T 8H7 55 plate.
Car running gr8 and pulling well. It has just been serviced and MOT'D in which it obviously passed emissions test. I now have code 0171 bank 1 too lean?. Once warm it is idling at about 1000 - 1100 rpm. Only just purchased car,
also have issue with fuel flap not locking is it easy to remove interior rear panel to access solenoid and does anyone know correct part no for this.
Regards
Gary
Old Jan 30, 2019 | 03:11 PM
Valpo A7's Avatar
Typically this is a vacuum leak. Look for broken or split hoses. You can listen for the leak as well
Old Feb 2, 2019 | 06:18 AM
Gills2019's Avatar
Hi Cheers.
Have now identified code P0507 via vcds idle control system rpm higher than expected intermittent. The tick over when warm is between 1000 & 1200 rpm
meternerd
Aug 1, 2013 06:01 AM
TT01Q
May 21, 2011 06:30 AM
lasondas
Oct 14, 2009 05:05 PM
rktskicar
VAG-COM Discussion
Sep 19, 2008 07:44 AM
Xel
12v V6 Discussion
Oct 25, 2003 07:47 PM
