Help... KO4 issue...
BUT...
at the same boost you are pushing more air with the k04 at a higher mass flow rate. you've probably reached the limit of the stock IC ability to cool that much air.
before making a purchase, you should log intake air temps and timing.
also, how were your oil temps on the track?
40hp for 1600. k04
80hp for 4500. apr stage iii
i think everyone would love to have a stage iii a4. its just very hard to justify. its definately a luxury.
a k04 is a resonable increase for resonable money.
hell, with the group buy that just ended, you couldve walked away with one for $1200.
One more thing...my setup is using stock spark plugs... someone told me that I absolutely have to run cooler plugs with the KO4 setup. Could this the culprit???
I'm no engineer but common sense tells me that my IC could not have gotten heatsoaked in that temperature. It was around 35F in my first session. The only other time I experienced something like this with my KO3, APR chip, and stock exhaust was when temp was over 90F. Sure, I lose some power all the time but not to this degree. Of course, I could be completely wrong.
Appreciate any comments.
I'm certainly no expert, but I don't see why it couldn't heatsoak in 35 degree temperatures. Sure, the low temp will make your intercooler that much more efficient, but if it's woefully inadequate for the task to start with, then it could still heatsoak. Think of the boundary case, where your intercooler is just a straight insulated pipe (i.e., no intercooler at all.) Then it's a closed system from the compressor all the way back to the intake, and the ambient air doesn't do anything to cool your intake charge.
So, in my opinion - the 35 degree temps will keep you from heatsoaking as quickly (or as completely?) because the initial air you suck through the airbox is cooler, and your intercooler is more efficient, but you could still heatsoak with an inadequate intercooler as your turbo heats up and compresses the intake charge.
But like I said, I'm no expert...
