Question: Any Ideas how Dahlback gets 600+ HP out of a Audi A4 1.8T?
#11
"my car is making near 500 crank on pump 91 and I am running max 30.5lbs boost." ....>
I can say almost the same for my car.....except the 30.5 psi is a little hi.
My turbo's maxed out though, if I want any more hp I'll need to upgrade.
#12
Good, there are a very few of us, keeping it alive is the trik - and using it is tough on the car
Where are you from Matt, if close we should meet up. I will be doing VIR and Mid Ohio and hopefully Lime Rock. Maybe we can talk face 2 face. I am in WV.
When you get up there, the car is a bit of a beast, the kind people always see from behind ;-)
Rod
Rod
#14
did u "near 500crank hp" guys do any tests ->
...like the stuff audi2ptzero was doing earlier ?
I tested a bit yesterday,
ran a 4450-6920rpm third gear run.
on my rs2 trans that equals 98-152km/h (=60-93mph? )
How do your cars compare ?
I am getting it dyno'd to the summer I guess, but I want to get it tuned better first, and run more than 19psi...
#15
Q club or Car guys. Where are you located.
That may be a bit soon 4 me, I am getting the KW V3 coilovers, front rear upper control arms from CPP, new sways and CPP sway links, some more bracing for the front of ar so I dont break anymore motor mounts. I should have car back ard 1st week of April and 2 weeks wont be enuf time to get used to the car b4 tracking it. Can you swing the June or July Mid Ohio? I like the thought of VIR w/a 1.5 mile straight after a 70 mph turn, but I dont know if they would black flag you if you exceeded 150mph which our cars should do easily. I am hoping Tim from TJM and some of his more built cars can show up too.
Rod
Rod
#16
I only do Q club. I'm located in Annandale VA. I don't think VIR black flags for hi speeds......
I could be wrong, but last time I was there, people were going pretty fast. Black flags are for unsafe driving, so as long as you're in control, and it looks like you're in control.....
Bada Bing
A4 (B8 Platform) Discussion
01-28-2008 07:37 AM
ByeByeA4 (AdamA418T)
06-11-2003 08:11 AM
