Is there any negative effect on the transmission if the rear wheels are further out than the front?
I'm looking at getting a set of IForged wheels with a staggered offset for a bigger lip in the rear. The offset would be 37mm in the front and 32mm in the back. This means that the back wheel will be pushed 5mm further out than the front wheel. Will this affect the transmission at all?
You will be find with the diffrent off set. the problem your talking about with the tranny..
The problem with the tranny only occurs when you run two diffrent tires of a diffrent hight on teh drive wheels. I.E. if you run a 15 inch tire on the right and a 16 inch tire on the left [front wheels] wheel and the car car is front wheel drive. You will stress out the tranny.
No worrys. And the bushings you will be waring out with 5mm diffrens wont ware out any more then normal. Well inless there put in wrong. However with hard driving the bearings and bushings should be expected to wear out sonner.
Peace, Thomas
Peace, Thomas
jonchavez
12
05-02-2005 05:49 PM
Haven Law
11-02-1999 12:05 PM
