Thoughts on experimenting with a boost controller...
How did you go about tweaking the MBC? Did you simply set it to a low boost setting and then did some 2nd / 3rd gear runs and adjust from there using the boost gauge? Or did you perform some VAG-log analysis?
For the same air mass, more velocity means a smaller area, smaller area means more restriction. If not done right, the restriction can cause a LOSS of flow into the cylinders.
It all boils down to the operating range of the motor. Small ports are good for low-end power, large ports are good for top-end power. The 1.8T is design as a low-end motor, why else would you have a small *** K03 on it?
I have no doubt the "small" port head is capable of big power numbers, but that offers no proof whatsoever that a large port head is worse.
I'm sure Corky Bell is a very smart guy, but I don't totally agree with everything he has in his book.
To quote WJM: "MAXIMUM BOOST" - the 156 page book that makes every internet weenie and car enthusiast into "a rocket scientist/engineer"
As for the "average" of 15whp of small versus large, that is way too misleading, you could gain low-end and lose top-end, and still claim "average gains.
What is the setup?
Where was the power gain?
Dyno sheets?
No offense, but I'm too stubborn to take the word of hearsay. There is too much mis-information floating around from he-said she-said BS.
oh and please dont put words in my mouth i never said that it was always the smaller the better i know that there is such thing as too small. (in regards to your placing restrictors to make 1/2 inch ports)
(details of my setup will be in place for discussion when i get it back in a week.)
oh and i do understand you on the hearsay. however, i dont see the relevance within your argument so in a way you contradict yourself with that.
