Performance and Tuning Discussion forum for various performance tuning techniques and questions
werid idling problem...
Old Apr 14, 2003 | 11:14 PM
spdracer53's Avatar
Default werid idling problem...
whenever i start the car cold, i get this weird idling problem where after the rpms drop back down to normal idle (720-780 on my car via the hvac display) my car stumbles and drops in rpms then bounces back up. this only happens after a cold start, and after the rpms are in normal idling range when i'm at a stop does it drop one tick mark down. i've brought this issue up with the dealer and they said they can't find anything that could be causing it. i thought it would be my giac chip, but i swapped it out with an apr chip with stock and chip modes and it did the same thing in both modes.
here are the mods on my car if it helps... 2000 a4 1.8tqm giac chip, bailey dv, scorpion exhaust, vdo boost gauge, greddy turbo timer.
anyone have any other suggestions on what to look for?
Old Apr 15, 2003 | 07:46 AM
Yippers®'s Avatar
Member
Default Check all vac hoses (again if necessary), clean the TB with a quality TB cleaner, see if you can
find someone local who does MotorVac or BG fuel system cleaning. How old are the plugs?
Old Apr 15, 2003 | 11:56 AM
ModifiedA4's Avatar
Banned
Default you may need to clean the idle contol valve...plus i believe there is a recalibration that can be...
done with vag-com. check the vac-lines and use good gas.
Old Apr 15, 2003 | 12:15 PM
Yippers®'s Avatar
Member
no ICV on the 1.8t and by swapping ECUs he's already done a TBA.
Old Apr 16, 2003 | 01:01 AM
moribundman's Avatar
Maybe the EGR valve is sticky?
Old Apr 16, 2003 | 06:59 AM
ModifiedA4's Avatar
Banned
didnt know about the icv, but im not talkin about a tba, something in read on the ross tech site.
Old Apr 16, 2003 | 11:30 PM
spdracer53's Avatar
egr?
Old Apr 16, 2003 | 11:34 PM
spdracer53's Avatar
Default i dunno how old my plugs are... i'm still under warranty
and when ever i have brought the car into service it hasn't started off cold so the tech can't see the rpm's drop.
 Michael S. Palmer
Old Apr 18, 2003 | 01:05 AM
The exhaust gas recirculation valve
sdb20
Sep 29, 2005 07:49 PM
beegee
Oct 2, 2002 08:47 AM
LOKE_IT
Jun 18, 2002 07:29 PM
LOKE_IT
Jun 18, 2002 12:00 PM
Captain
Jul 22, 2000 11:41 PM
