Technical specifications - mistake
Old 02-12-2018, 05:23 AM
  #31
AudiWorld Expert
ex-quattro PETE's Avatar
Originally Posted by spijun
Do you know the size of that space?
Please go to the nearest Audi salon and see what you write about the space in A5 without shelf
Dude, lay off me. It's you who has a problem with Audi numbers, so you go and measure it yourself and then go complain to Audi that you think they made a big mistake. I couldn't care less.
I gave you a possible explanation. If you don't like it, just ignore it and wait for someone else to give you a better one.
I'm done here.
Old 02-12-2018, 06:13 AM
  #32
spijun's Avatar
You stuck to my post not on yours
You're asking me stupid explanations about the measures, this is are not my data , but the factories. The data of the Audi factory are recognized all over the world.
You are trying to justify the non-existence of a measure, but you have not given any answer.
Why are there differences in measurement for Q3 and Q5 / Q7. The shape of the car is the same.
You did not explain how A4, A6, A8 have less space in the luggage compartment
Old 02-12-2018, 07:25 AM
  #33
apoelistas's Avatar
It is not a mistake. One volume is the boot space with the cover/separator installed. The other volume is with the cover/separator removed.
I believe they should publish both boot volumes, but each region uses one or the other, not sure why (maybe laws/regulations)
Prooven with the exercise in my previous post above. I am sure you will be happy with that explanation since it is mathematically proven.
Old 02-13-2018, 05:08 AM
  #34
spijun's Avatar
Proof that there are companies that respect factory data ( Mercedes USA)
19.5 cu-ft = 550 lit ( Seats up )
56.5 cu-ft = 1.600 lit ( rear Seats down )
Old 02-13-2018, 06:29 AM
  #35
apoelistas's Avatar
If you add the optional (standard on the SQ5) Rear Bench Seat Plus Pack, you get sliding and reclining rear seats that, when slid all the way forward, increase boot space to 610 litres (from 550). That's among the biggest in the class
So it depends.
Old 02-13-2018, 06:52 AM
  #36
AudiWorld Expert
You still don't get it. It's not a difference between seats up and seats down that we are discussing. It's a difference between seats up (below cargo cover) and seats up (floor to ceiling).
If you take your Mercedes GLC example, the 19.4 cu-ft value they show must be the max value (floor to ceiling) because they also show this: 17.6 cu-ft (seats up, below cargo cover):
At least MBUSA is nice enough to specify what that number means. Since Audi USA did not specify how they measured their cargo volume, we can only guess.
Old 02-13-2018, 07:27 AM
  #37
apoelistas's Avatar
I know what you meant since I already gave you an answer previously. I added additional info on 550 increase to 610 liters as a general discussion on boot volume seats up with boot cover sepator installed in order to compare with GLC.
Old 02-13-2018, 07:31 AM
  #38
spijun's Avatar
Go back and read what's written there:
Cargo volume (Manufacturer): 19,4
In the rest of the world, the luggage compartment is under the lid, which is 550 Lit
Who can measure it above the lid, who will put a suitcase here or something, so when you suddenly press the brake , opportunity to hurt the passengers in the back seat
The other thing is that if you put something up there, how will you have a look back ??? How to see in the rear-view mirror behind you ?
  #39
apoelistas's Avatar
Light items on top only. I always raise the 3 head rests a bit, in addition, for more protection, but I make sure there is an opening for rear view.
That space is usuful to me irrespective.. when I use the space I remove the boot separator from the Q5 in order to arrange items better in order to avoid what you are discussing.
Old 02-13-2018, 07:55 AM
  #40
AudiWorld Expert
But it does not specify how that cargo volume was calculated. That is my point. Based on the other number I showed you (17.6), what do you make of this 19.4 number?
And I already explained to you that it's not always the same in the US. It's very poorly standardized in the US, which makes comparisons from one vehicle to another difficult for the buyer. It's crap, I agree.
Again, there are standards in the US that allow for this area to be measured and included in the overall calculation.
You don't have to put anything on that shelf. You can REMOVE the shelf and then place a tall object in the trunk that reaches from the floor to the ceiling. Just think of it as if the shelf was not there.
Is it safe? Of course not. But that has nothing to do with the measurement regulations that we have in the US that allow this area to be included in the calculation.
If you drive a fully loaded pickup truck, you will not be able to see anything in your rear-view mirror either, yet it is allowed here.
Quick Reply: Technical specifications - mistake
