Technical specifications - mistake
#31
AudiWorld Expert
Dude, lay off me. It's you who has a problem with Audi numbers, so you go and measure it yourself and then go complain to Audi that you think they made a big mistake. I couldn't care less.
I gave you a possible explanation. If you don't like it, just ignore it and wait for someone else to give you a better one.
I'm done here.
#32
You stuck to my post not on yours
You're asking me stupid explanations about the measures, this is are not my data , but the factories. The data of the Audi factory are recognized all over the world.
You are trying to justify the non-existence of a measure, but you have not given any answer.
Why are there differences in measurement for Q3 and Q5 / Q7. The shape of the car is the same.
You did not explain how A4, A6, A8 have less space in the luggage compartment
#33
It is not a mistake. One volume is the boot space with the cover/separator installed. The other volume is with the cover/separator removed.
I believe they should publish both boot volumes, but each region uses one or the other, not sure why (maybe laws/regulations)
Prooven with the exercise in my previous post above. I am sure you will be happy with that explanation since it is mathematically proven.
#34
Proof that there are companies that respect factory data ( Mercedes USA)
19.5 cu-ft = 550 lit ( Seats up )
56.5 cu-ft = 1.600 lit ( rear Seats down )
#35
If you add the optional (standard on the SQ5) Rear Bench Seat Plus Pack, you get sliding and reclining rear seats that, when slid all the way forward, increase boot space to 610 litres (from 550). That's among the biggest in the class
So it depends.
So it depends.
#36
AudiWorld Expert
If you take your Mercedes GLC example, the 19.4 cu-ft value they show must be the max value (floor to ceiling) because they also show this: 17.6 cu-ft (seats up, below cargo cover):
At least MBUSA is nice enough to specify what that number means. Since Audi USA did not specify how they measured their cargo volume, we can only guess.
#37
You still don't get it. It's not a difference between seats up and seats down that we are discussing. It's a difference between seats up (below cargo cover) and seats up (floor to ceiling).
#38
Go back and read what's written there:
Cargo volume (Manufacturer): 19,4
In the rest of the world, the luggage compartment is under the lid, which is 550 Lit
Who can measure it above the lid, who will put a suitcase here or something, so when you suddenly press the brake , opportunity to hurt the passengers in the back seat
The other thing is that if you put something up there, how will you have a look back ??? How to see in the rear-view mirror behind you ?
#39
That space is usuful to me irrespective.. when I use the space I remove the boot separator from the Q5 in order to arrange items better in order to avoid what you are discussing.
#40
AudiWorld Expert
If you drive a fully loaded pickup truck, you will not be able to see anything in your rear-view mirror either, yet it is allowed here.
