aftermarket exhaust
#11
A supercharger helps you no more than a NA motor since the amount of air forced in is static because it is on a belt. The only way to change it is by changing the size of the pulley. This is why I am thinking about doing a tune/pulley mod to get back that 95HP. Turbochargers should make up for most of the O2 loss, but there will be considerable turbo lag.
#12
I am moving to Breckenridge, 9500ft. HP Loss = (elevation x 0.03 x horsepower @ sea level)/1000 Comes out to be 95HP loss. Denver would be 54HP.
You can't get big gains without changing the supercharger pulley which at the elevation will make a huge difference. I wish it was turbo charged instead of SC.
Wow, that's up in the mountains. Didn't it would be nearly doubt Mile High.
#13
Yea, it will be quite an adjustment of driving. I am going from an M3 at sea level to a Q7 at high altitude. I am going to give it a month or so before I void an engine warranty for 90hp. The nice thing is engines rarely have issues. I have never had one in my lifetime. Knock on wood.
#14
Having said all that. I'm not sure how over, under or properly sized SC is in the 3.0 motor. Looking at some power curves and when bleed valve opens up it looks like the system does have some extra boost capacity. However, since it's roots type SC, so only about 40~50% efficient, I'm pretty sure there is a significant % of power loss at altitude, but I don't think it's as drastic as you think. Yes, there is no way to recover the lost power without some mechanical upgrades, or NOx. However any changes that would help you at altitude, could hurt your motor at sea level. So all in all, hey you were right, turbo would have been better in your case and location :-)
I love this theoretical discussion, but to be perfectly honest, the only way to know for sure is to put the car on the dyno at sea level and then at altitude. Anything else is pure speculation.
#17
I think I have read users say that the RaceChip won't trigger anything to void the warranty. If you go in for service, take it out, but if it throws codes, can't you just clear them with an OBD reader?
Dabozo
04-19-2015 03:32 PM
Reggie
Q5/SQ5 MKI (8R) Discussion
03-02-2009 06:21 AM
TurboEnvy52
01-08-2007 08:03 PM
VandyS4
04-23-2004 07:57 AM
MAC225
02-07-2001 01:42 PM
