Ambient LED Light Flicker
I have 2017 Prestige and have been noticing the front passenger door and rear left passenger door ambient light flickers only when on the blue setting. I change to red, white, or any other color on the spectrum and it does not do this. (In the video I am not adjusting the brightness on the MMI ****, it is set to full brightness) Has anyone else experienced this?
If the light was flickering at a much faster rate, much like a strobe then that would signify a problem with the physical connection, either solder joint or at the plug. That would also most likely happen during movement or impact. Since the vehicle is stationary, what I see leads me to believe there is an issue with the LED controller on the blue light. That most likely means module swap.
ekyp
A4 (B9 Platform) Discussion
84
04-14-2022 08:11 AM
NullTerminator
03-05-2007 03:44 PM
