Bluetooth instructions?
maybe i was buggin' but where are the directions to setup a new phone on the bluetooth in the car? I didn't think i saw it in the owners manual....
your dealer should have done it for you when you took delivery.
it should be in the manual, but it differs slightly depending on what phone you have. basically you have to go into your phone's BT settings, turn BT on, and select 'make discoverable' while the car is on. after a few seconds, it should find the car and ask for a password, which is '1234', IIRC. then they should pair up.
if all else fails, go back to your salesman and ask for help.
On your RNS-E....
press the phone button. Then press settings. You can change the BT pin code in there if you wish. Like above, make your phone discoverable. Then it should find the Audi BT. Enter pin code. Done. Car must be on, i.e. you can't just push the power button on the RNS-E, you need the key turned in the ignition for the BT to get power.
Mr. Head
11-01-2005 06:26 AM
