Has anyone VAG-COM'd their 08s to eliminate the seatbelt chime?
Re: Has anyone VAG-COM'd their 08s to eliminate the seatbelt chime?
i did it. the codes posted here by someone in a pdf file didn't work. but i figured it out with the hints in the vag-com screen. i borrowed the vag-com from someone so i don't have it anymore to see what code i used. i think when you open a value or hover a value a window pops up with examples and that's how i figured it out.
I did both an 07 and my 08
I'm in NYC right now and do not have access to the PC that I have my notes on. While the exact coding of the 2 vehicles was different, the digit to change is the same in both years and the change is the same in both years (6 to a 0 or whatever it is).
Hope this helps. I'll be home tomorrow and try to recheck this post and see where you are with it.
some changes I've done... nothing new here tho,,,
Address 9 central elec
1021 enables fog with high beam; Euro parking lights (blinker arm turns on left or right lights when parked)
Address 17 instruments
23259 disables seat belt chime
Address 46 central conv
11884 all windows up/dn with keyfob hold
11880 also enables all door unlock with one press on fob
did the fog mod too, but it's not as good as on the B5 where only the front fogs light at the push of the switch
schalliol
07-18-2015 03:14 PM
AaronL
03-06-2009 07:32 AM
PimpluxA4
12-26-2002 03:53 AM
