S4 (B6 & B7 Platforms) Discussion Discussion forum for the B6 Audi S4 produced from 2003-2005 And B7 Audi S4 produced from 2005 -2008
Just bought H & R CO's...any tips/advice/problems for instillation?
Old 08-24-2005, 01:23 PM
New Member
meeko1's Avatar
Old 08-24-2005, 04:20 PM
Member
Blau Flash's Avatar
dont take it to meineke...LOL
Old 08-24-2005, 06:28 PM
petethegreat's Avatar
Default Find a shop that does corner balancing....
Usually porsche shops have the proper machines to do the allighment. Have them do the install. You will pay alot more for the install than some reg. shop but it will be done right. Dont go below an inch drop. The ride gets alot worse on the h and r COs if you go too low. 1 inch to 1 1/2 inch is perfect. Also because you have the h sport sways if you go too low you will make less use of the sway bars. Dont forget you get what you pay for . Dont cut corners. Let a real pro do the work. H and r CO's are great coilovers if the work is done properly.
Old 08-25-2005, 08:16 AM
JMSIV's Avatar
Default If you plan to DIY, you can drop me an email. I did mine...
more than once (because I kept screwing little things up). But its all solid now, and it's not that bad an install - if you know a few tricks.
Oh, and I had zero prior experience, only standard tools (borrowed a spring compressor from Advanced to get the factory front struts apart).
FUGLY AUDI
9
05-28-2004 11:03 AM
COT51E-ukcab
19
09-23-2003 04:31 AM
mystique
Performance and Tuning
01-06-2001 04:26 PM
Diamond Joe Quimby
10-17-2000 12:19 AM
Quick Reply: Just bought H & R CO's...any tips/advice/problems for instillation?
